'72 wiper motor - this SHOULD be a ground, correct?
Hi,
I'm working on a friend's '72. I just got the motor back in, and in the process of hooking things up. The car was in pretty nice shape but, like most cars this old, people have done some strange things! I've got notes, photos and some video, but would still appreciate being double-checked. I had to leave the country to check on a family member, and the car sat for a month without me touching it (memory isn't what it used to be!).
On with wiper motor, this terminal IS for "ground", correct?
And does that appear to be the correct connector for that terminal?
What is causing me to pause and question this, is that the wire used is "red" with red shrink-tubing on it. Using all-red for a ground triggers my OCD!! This wire has a ring-terminal on the other end, and was connected with a bunch of other wires with a bolt holding the torque converter dust cover on (also seems like a poor way to connect grounds).
Thank you
Thank you
1967 Pedal Car Champion
That does appear to be the correct wiper motor case ground. It should be under one of the screws for the washer pump attachment. As for the other end of the ground... I don't know because it's buried in my wire harness and not independent. You can easily get a wiring schematic here on the forum with a search. I'll look up mine and see what I can add.
CamByLee (07-15-2022)
The wiper motor is connected to the blower motor and then to starter as a ground.
Thanks! That is a better diagram than what I was working with.
Somebody previously added a VintageAir system, so the original blower motor is gone. I found some wires dangling, not connected to anything, and I suspect those went to the blower.
There are a few other wires that have been clipped, but not capped off - I HATE to find things like that!!
a lot of things like head-park and tail lights, horns, stuff like that ground to the shgeet metal bracket they attach to. and they in turn have to be grounded to the frame or engine. a tail light can lose ground in about 6 different places.
Received 3,229 Likes
And GM did the ground wires in the harness a really cheesy way- here's the headlight harness grounding- so adding an extra from the wiper motor would not be a bad idea-
CamByLee (07-16-2022)
