C3 Power Steering overheating???
I kind of wonder if these rebuilt valves are getting built properly? Might be worth disassembling to see. This video is very good on how to rebuild the valve. Might discover something.
Michael
Michael
https://www.corvetteforum.com/forums...-question.html
If there is no restriction, there is a lot of flow, but no pressure, and not much heat.
The ram control valve offers a restriction (when wheel turned) and this makes the flow drop and makes the pressure build. It can hit 1300-1600 psi.
There is also a pressure relief valve in the pump so it will not go too high and go over the set pressure, It then bypasses internally. The pressure makes heat.
I vote for it is making pressure all the time, with very little flow, because of some restriction in the PS control valve. It is constantly bypassing under high pressure in the pump, making heat. To overheat in 10 minutes must mean you have almost no flow. The control valve needs dissasembled, inspected, and carefully centered.
The pump will push almost 20 GPM if there is zero restriction. The first restriction is the control orifice in the back of the pump. 1.5-2.5 to 3.0 GPM rating, depending on application. That makes the pump build pressure to somewhere around 600-900 PSI at the back of the pump, even at idle, with the internal relief valve running 3/4 open and bypassing the rest. 900 psi makes testing the HP line very tricky.
The PS control valve further restricts the flow below 1.5 GPM, making the pressure climb even higher.
The return line is low/no pressure. You could replace that with some clear tubing for testing purposes. Or let it fill a jar and test the flow. Somewhere in the 1-2-3 GPM range. That's a gallon in 20 seconds. Just do not let the reservoir run dry, even for a couple seconds, or you will burn the pump vanes. It would take some "Mcguyver" engineering to do this at home and actually measure the flow. Simpler would be to just insert the return line flow into a big clear tube and then that tube into the pump, and just ensure you have a lot of flow, near 2 GPM. To heck with measuring it.
I have to believe the pressure relief spring/valve in the pump is working properly or you would have popped the HP line already. 1300 psi is normal when restricted.
GM PS by MotorTrend
Michael
Have you run thru the adjustment procedure in the service manual? I believe it is done with the wheels off the ground?
I'll see if I can find it. Here is the control valve balancing procedure from the chassis service manual. Disconnect the power ram. Start the engine. When balanced "the control rod should be able to be moved in and out by hand" meaning it is getting no pressure applied to it.
In the testing section it also mentions it may take 5-10 lock to lock turns to get the fluid temp up to temp for testing 150-170. With that happening at idle it still sounds like too fast of a temp increase.
Michael
If the system has too little flow, that would max out the pressure, and the heat build-up.
The Corvette pumps run lower pressure than other chevys. Your rebuilt one may be too high. That is controlled by the spring in the back of the pump. And if the flow is also too low.... C3 870-1000....others 1350-1450... You could swap the spring back to the original one, and the flow orifice also.
They make gauges to check the psi, but it is easier to check the return flow, just clear tubing. But it's not very scientific unless you have something to compare it to. Unless it is very low and obvious.
Michael
PS
Probably very important, I used Delco power steering fluid and
made sure I didn't overfill. I bleed the air out of the lines with the car off
the ground with no front wheels and rear tires still on the floor. So the air
bubbles would go to highest point which was pump.
Michael
Michael
