1979 corvette auto trans fluid type
Old Aug 8, 2022 | 05:14 PM
Budltbeard's Avatar
Budltbeard
Default 1979 corvette auto trans fluid type
Hello once again! I know Dex3 is recommended for th-350 but it seems dex/merc has replaced it. Google search shows this when searching for dex3. Will this work ok? I am putting in an aluminum pan with a drain plug and plan to to do the drain/refill a few times. The fluid was dark brown and completely worn out. Thanks!
Old Aug 9, 2022 | 10:20 AM
SEVNT6's Avatar
SEVNT6
Dex/Merc will work just fine, and GM says Dexron VI is backward compatible...
Old Aug 9, 2022 | 12:59 PM
Budltbeard's Avatar
Budltbeard
Thanks SEVNT6! Really needed the clarification.
To 1979 corvette auto trans fluid type
