Setting rear toe after installing Ridetech bits
Old Aug 9, 2022 | 02:27 PM
JOZW30's Avatar
JOZW30
Default Setting rear toe after installing Ridetech bits
71 custom (my first C3) Ridetech rear setup, new bearings, new wheels and tires, etc….
I know to adjust shims and maybe this is a dumb question but how do I know if both wheels are basically parallel to the centerline of the car to start with? Do the new trailing arms and shims make it “close”?
I matched the exiting shim packs when I put the new shims in but I can’t vouch for the previous owners work.
Wheels are toed out about 1/4” but how do I know that they should be both adjusted? Making my head hurt….
thanks!
Old Aug 9, 2022 | 05:49 PM
Mooser's Avatar
Mooser
I projected a line across each rear rim up to the front and measured in to frame center, and double checked to the front spindle centers, (which unless you know where they are could be different on each side)
Comparing both sides to determine rear thrust.
Then when I checked the rear toe I made the shim adjustment to correct the thrust and toe accordingly. Once thrust is in you can keep working on toe but need to make sure your not screwing the thrust back up
M
Old Aug 9, 2022 | 06:02 PM
Mooser's Avatar
Mooser
Here's where I got most of my info from
https://www.corvetteforum.com/forums...-location.html
M
Old Aug 9, 2022 | 06:04 PM
JOZW30's Avatar
JOZW30
Thanks! I did see the “thrust angle” measurements since I posted. So the side frame rails run parallel under the length of the door?
Old Aug 9, 2022 | 06:05 PM
JOZW30's Avatar
JOZW30
I will read tonight, thanks!
Old Aug 9, 2022 | 06:14 PM
Mooser's Avatar
Mooser
yes but it really doesn't matter as long as you measure in from the projected line at about the same distance along them.
The father forward the larger the readings will be so it's easier to see the difference type of thing
M
To Setting rear toe after installing Ridetech bits
