Hello.
when I removed the engine I forgot to remove 1 bolt from bell housing, I pulled on the engine to separate from trans and the trans popped forward with engine, I knew then, I was going to have issues with the shifter, I had a previous leak on trans yoke seal, and it deteriated the trans mount, I never messed with my linkage. It always worked great before this. Can any adjustments be made from the interior side or underside?
thanks in advance
https://youtu.be/l-zlrja0Hew
2016 C3 of Year Finalist
what is the specific issue. you arent talking in the video so I dont understand what is wrong. It is spring loaded to go to the 3-4 gate and that looks like it works and it looks like you are getting all the gears. The only thing I can think happened when you pulled it is you bent one of the linkage arms, If the linkage was disconnected Then nothing would have happend to the shifter itself.
I took the boot off under the console, and checked underneath the car, the linkage looked to be ok, I didn't see anything that could of been bent..for the heck of it, I sprayed some wd40 on the linkage from the interior side, and it became free again... I also left my ignition key on from last year, when I did the suspension and that was stuck also, luckily after a minute or two that that would free up.. so far I am good to go..
There is a hole in the side of the Shifter body that You insert a Pin which locks the Shifter . You then check the adjustment of the Linkage Arms. I'm sure there are U-Tube videos showing the procedure.
Sounds like you're Getting lucky, you should buy some lottery tickets while it lasts!!
If something did get tweaked, here are the installation / alignment instructions. You can use a 1/4 drill bit to lock the shifter while you adjust everything. https://documents.holley.com/3738616_instructions.pdf
