Help, ignition lock stuck in on position
Old Aug 21, 2022 | 11:15 AM
dr_nuker's Avatar
dr_nuker
Cruising
Default Help, ignition lock stuck in on position
Hello, i hope you can help me. Today my ignition lock got stuck while the car was running, i was not able to turn off the car nor remove the key. i have managed to shut off the car by pulling the manul choke and turning on the AC system then i disconnected the battery. Now this is the situation:
I still can turn on the engine because when i connect the battery the key is still in on position and i can turn it but i can't shut it off. To be precise my ignition lock was already not working correclty because i could turn it without the key in and i was planning to change it. Today when i shut off the car for the first time i had the feeling that the key was a little bit stuck but it turn eventually, the second time the key was completely stuck. Any suggestion?
Old Aug 21, 2022 | 11:24 AM
MelWff's Avatar
MelWff
No mention of year or transmission type but you probably have the steering interlock feature. With the car in park or if manual, in reverse, with key turned as far as possible to Off, open the hood. You should see a lever where the steering comes out of the firewall with a cable attached to it. Pull up on the lever and then try to remove the key.
Old Aug 21, 2022 | 11:27 AM
dr_nuker's Avatar
dr_nuker
Cruising
yes you are right, i forgot to say it is automatic but i thought that the 77 did not have the steering interlock feature, am i wrong?
Old Aug 21, 2022 | 11:35 AM
sunflower 1972's Avatar
sunflower 1972
Maybe this will help you:https://www.corvetteforum.com/forums...-position.html
Old Aug 21, 2022 | 11:37 AM
MelWff's Avatar
MelWff
Open the hood and look. Parts vendors list the cable for 77 with automatic
Old Aug 21, 2022 | 12:21 PM
dr_nuker's Avatar
dr_nuker
Cruising
just checked, nothing there... any other suggestion?
Old Aug 21, 2022 | 01:42 PM
MelWff's Avatar
MelWff
try spraying some lock lubricant in the cylinder but beyond that will require disassembly of components
Old Aug 21, 2022 | 01:50 PM
dr_nuker's Avatar
dr_nuker
Cruising
I have sprayed some lubricant 10 minutes ago, Will retry later. Do you think i have to replace the lock cylinder? Or could It Be something else?
Old Aug 21, 2022 | 03:23 PM
sunflower 1972
Just a suggestion, but you may want to consider purchasing one of these.
To Help, ignition lock stuck in on position
