1977 wiring harness change?
Old Aug 22, 2022 | 12:00 PM
TechnicalPelican's Avatar
TechnicalPelican
Cruising
Default 1977 wiring harness change?
I recently bought a 1977 corvette serial number 08630, and it has a new dash harness in it. The interior harness is not getting power from the battery because the firewall connection pin on the engine harness side does not interface with anything on the inside. My car also has the old-style gauge cluster without the circuit board and speedo/tach. The harness has the connection for the new style gauges with the pcb. I was wondering if the gauges changed from the old style to the circuit board style mid-year like many other things with the 77s did, if not, then what harness should I need?
Old Aug 22, 2022 | 12:24 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
The 77s didn't change the gauges between early and late as far as I know. Post some pictures of it.
Old Aug 22, 2022 | 12:54 PM
stevedinino's Avatar
stevedinino
My 77 is serial number 00164 (august 76). It has the pcb for the center gauges.
Off the top of my head, the only wiring change I recall was for the alarm. Might be something I’m forgetting tho.
Old Aug 22, 2022 | 02:00 PM
bmotojoe's Avatar
bmotojoe
By the VIN given your 77 is a early build or first design.
On the early builds there were 2 different main dash harnesses that would have been installed, one for a Manual Transmission or one for Automatic Transmission.
Either of the Main Dash Harnesses would have had the connector for the Center Cluster Gauges PCB board.
Your early build has what they called a TAP connector and there is a couple different configurations of of that...
With A/C
Without A/C
The TAP connector is located down below the Master Cylinder area photo below, this TAP Connector is configured for a A/C car with the Hood Light.
Here is a drawing I made that includes the TAP connector and the single Starter Solenoid #10 RED wire (fusible link "A").
This drawing also includes the Forward Lamp Harness to bulkhead connector (fusible link "B")
NON A/C left A/C right
Old Aug 22, 2022 | 02:12 PM
bmotojoe's Avatar
bmotojoe
And here is the early charge circuit.
Notice Figure A on the right page, that is the TAP connector
And "FROM STARTER SOLENOID" that is a single #10 RED wire that is protected by fusible link "A"
Old Aug 22, 2022 | 02:42 PM
bmotojoe's Avatar
bmotojoe
I will also provide another photo showing bulkhead connector circuits and the differences between the early and late harnesses.
Is it possible you have a Late new Main Dash Harness?
Old Aug 22, 2022 | 02:49 PM
TechnicalPelican
Cruising
It's possible I have a late harness in the car, as it was changed before I bought it, I have come to the realization that the gauges have also been replaced by the early c3 gauges, and do not hook up to this harness. It would also explain why I am not getting power to any interior components, as the pins seem to be in all different placeson the later fuseboxes.
Old Aug 22, 2022 | 03:40 PM
TechnicalPelican
Cruising
I just checked the pins and have confirmed that o have the late harness in my car, so I will be getting in touch with the previous owner to get ahold of the original harness. I have one question, are the center console gauges from the 79 year compatible with 77?
Old Aug 22, 2022 | 04:20 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
They should be the same as a 77
Old Aug 22, 2022 | 07:38 PM
bmotojoe's Avatar
bmotojoe
The center gauge clusters were virtually the same from 77-80 other than the gauge needle colors.
"I think" starting in 1981 the clock was replaced with a oil temp gauge...
To 1977 wiring harness change?
