Rear End Ratio
Chalk the front tires and place the transmission in neutral.
Do this safely using jack stands as a minimum.
Mark the passenger side tire with a single line from the bottom of the rim towards the ground.
Mark a line along driveshaft from the rear u joint forward about one inch.
Rotate the passenger tire in the forward direction only one rotation and count the rotations of the driveshaft.
Approximately 3 rotations of the driveshaft equals a 3.08 rear gear.
3 1/3 rotations equals a 3.36 rear gear.
3 1/2 rotations equals a 3.55 rear gear.
3 3/4 rotations equals a 3.70 rear gear.
4 rotations equals a 4.11 rear gear.
4 1/2 rotations equals a 4.56 rear gear.
Thats it!
I’ve never done it with just the hub and no tire.
Thats it!
not the main one. Which I give up for the night, as it looks hard to do with everything (that tin cover, spare tire) as I can't see the Ujoint/main drive shaft at all from the drivers side, and barely see it from the pass.Thx!
You can mark the driveshaft anywhere along it where the line is visible and still get the same outcome.
We all learn from some point.
Never hesitate to ask.
I still ask some boneheaded questions.
If the rear of the car is up on jackstands, you should be able to see the main driveshaft just behind the trans without too much difficulty. If you still can't see it perhaps you need to get the car a little higher on those stands.
And by all means make certain to chock those ft. wheels.
SAFETY FIRST. Your life depends on taking the necessary precautions to prevent a disaster.
Know that when you jack, the suspension goes to full travel, resulting, for the C2/C3, a condition that causes the halfshafts to bind, inhibiting rotation. You need to jack and support, properly, the car on the frame, then slightly raise the suspension about an inch to avoid the aforementioned binding.
But yea, it is jacked up well, all 4 tires are off the ground (long story, but I took all my tires off to bring them to my detailer so he can polish my wheels) with 2 jack stands on each side on the frame right behind (front tires) and infront (back tires) with the jack under the pumpkin (but not on it to mess up that tin "heat shield" unless if actually falls).
But yea, I'm not there now, but the ujoint going into the pumpkin (main driveshaft, lol) is hard to see, I can see the very bottom of it. Are y'all talking about marking it where it goes into the tranny (didn't even look there), or pumpkin? Anyway, I'm waiting till I get my tire back tomorrow so it's easier to turn and look at the mark at same time.
