oil leak
Old Aug 26, 2022 | 11:10 AM
robertbowman623@gmai's Avatar
2nd Gear
Default oil leak
Just came back from a drive and over night about 2 quarts of oil leak out from around the front of the small block. Dripping off where you set the advance. Appreciate any thoughts..
Old Aug 26, 2022 | 11:30 AM
stevedinino's Avatar
stevedinino
Sounds like the timing cover seal went bad.
Old Aug 26, 2022 | 01:30 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Could also be the oil pan gasket in the front. Small block chevys had 2 different thicknesses in the front and they will leak alot as well as the loose cranks seal
To oil leak
