Carb Fuel Boil
They have been manufacturing header systems for over 50 years and their quality is top notch.
Their shorty headers are awesome and on their website you can see the dyno runs they did and compared their shorty headers with long tube headers and stock ram horns.
They ceramic coat the interior and exterior of their headers and they really reduce the under hood temperatures.
Their welds are so perfect they actually recommend bolting them up without gaskets.
I think they are the best quality headers on the market.
If you don’t like the idea of going to headers they also manufacture cast exhaust manifolds that many people swear by.
I also believe that you should install either a carb spacer or an oem type heat plate to help the problem.
- L48 mostly stock engine with an Edelbrock 1406 carb
- Yes there is a return fuel line.
- 16" electric fan mounted directly to the radiator, it moves alot of air.
- starter has no issues cranking the engine (typically the car will start almost immediately when I crank it)
- carb was devoid of fuel during this scenario
- Tested temps with my infrared thermometer and the gauge is correct.
I read a lot, and I mean a LOT of overheating threads on these forums and there are two themes running through all of them.
1. These cars worked properly with the factory engineered cooling systems, so try getting as close to them as possible, and
2. Everyone who has a cooling problem seems to think they are smarter than the factory engineers and mods the hell out of the cooling system looking for answers. And usually not finding them.
Stop treating the symptoms and get to the root cause.
Several on here have mentioned timing as a huge contributor to excess engine heat, but I didn’t see where you addressed that.
Sorry if I came across as rude but I want (like pretty much everyone wants) you to get your problem solved and be enjoying your wheels instead of stressing about them.
