1st time using timing gun -- basic questions (with pics!)
Old Sep 6, 2022 | 08:56 PM
derekderek's Avatar
derekderek
if you rev it to 4500 and it is still at the same advance setting as at 2800, it is fully advanced.
Old Sep 7, 2022 | 12:22 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
...is the heat riser still installed if exhaust manifolds? make sure it is open. best way is to remove it. second best is to remove the flapper. 3rd is to wire it open.
Originally Posted by Muuhaha
And yeah it's hotter on the passenger side. Side pipes. The heads don't have the heat riser but I got the gasket that blocks it off
Derek is talking about the heat riser valve on the exhaust manifold at the junction between the manifold and the exhaust pipe - sounds like you are talking about the intake manifold passageway under the carb. A stock heat riser valve has a thermal spring flapper that often rusts in the closed position, blocking the passenger exaust. A lot of owners remove it altogether and put in a dummy spacer, or they cut out the flapper, or they free-up the rusted one.
