Engine backfiring after rebuilding top end
Old Sep 3, 2022 | 04:15 PM
antevans245's Avatar
antevans245
5th Gear
Default Engine backfiring after rebuilding top end
I recently finished rebuilding the top end on my 350. Got rid of all the smog parts, new heads, cam, exhaust, and carb. Every time I try to start it now it cranks for a few seconds and then it backfires. Sounds like a gun going off in the engine bay. Id really appreciate any advice or help anyone can offer. I've tried adjusting timing. I know for sure I have the right firing order and I dropped the distributer in on TDC. Thank you for any help!
Old Sep 3, 2022 | 04:45 PM
derekderek's Avatar
derekderek
Plug wires on wrong. First, unhook ignition and crank it listening to it. If one hole has no compression cuz valves too tight you will hear it. Then 18436572. I bought a vortec engine that was junked cuz they couldn’t find the miss. 9 plug wires. One went from cap to atmosphere. One went from plug to atmosphere. The other 7 hooked up correctly. It is so easy to screw up with plug wires.
Old Sep 3, 2022 | 06:08 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
chain off a tooth or more likely, dist 180
out
Old Sep 3, 2022 | 06:25 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The bang sounds like dissy 180 out. You may have dropped it on number 1. But on the wrong stroke. Easy fix. Pull dissy cap back off. If rotor is pointing straight backwards. Pull dissy and restab with rotor pointing straight forward. Another words just give that dissy a 180 turn.
Old Sep 3, 2022 | 06:46 PM
kossuth's Avatar
kossuth
I would initially guess the dizzy is 180 out as well but you can get the exact same behavior from a intake valve hanging open. With the rotor pointing toward the number one both the intake and exhaust valves should be closed on the number 1 and the exhaust and possibly the intake valves on the 6 will be open/opening.
Old Sep 3, 2022 | 07:01 PM
antevans245
5th Gear
Thanks for the advice. I'll be sure to check all my plug wires again. What would it sound like if the valve is too tight?
Old Sep 3, 2022 | 07:04 PM
antevans245
5th Gear
What would cause a valve to stay open? Would that just be because I tightened the rocket arm too much? And would one valve staying open keep it from starting? I thought it would of been able to at least start from the rest of the cylinders
Old Sep 3, 2022 | 07:51 PM
kossuth's Avatar
kossuth
If you tightened them all too much then yes it would prevent it from starting
Old Sep 3, 2022 | 07:53 PM
derekderek's Avatar
derekderek
hung up or set too tight valve will make the engine crank faster thru that 1 cylinder. this is a v6 with bad compression in 2 holes. go to about 56 seconds on the vid. you can hear 1-2-3-bad-1-bad-1-2-3-bad-1-bad
Old Sep 3, 2022 | 09:32 PM
HeadsU.P.'s Avatar
HeadsU.P.
antevans245,
If I understand your original post, you are firing up this rebuild for the first time. You need to slow down and put a lot of thought into this.
Number one priority is to NOT crank & crank & crank. I assume this is a new flat tappet cam that needs to be broke-in.
The more you crank on it, the more you remove the break-in lube.
A fresh rebuild with new cam needs to fire immediately to avoid cam lobe / lifter damage.
I would pull the valve covers. Disconnect the coil wire. Then with the drivers window down, reach in and just jog the IGN key. No cranking. No spinning. Just jog.
Watch the rockers especially # 1 exh & Int. Watch for the Int to close. Note where the timing mark is on the dampener. Lift dizzy cap and verify rotor position at #1.
Note any rockers that refuse to loosen up. As others said, maybe over done valve-lash settings.
You should be able to check all 16 with only a few rotations of the crank.
Old Sep 3, 2022 | 09:52 PM
OMF's Avatar
OMF
THIS^^^^^^^^^^^^^^^^^^^ is what you need to do
Old Sep 4, 2022 | 12:06 AM
antevans245
5th Gear
Originally Posted by HeadsU.P.
antevans245,
Thank you so much for your reply. I will try this in the morning. I've already accepted that I might have to replace the cam, but I figured with how much I've learned throughout this job its not the end of the world.
Old Sep 4, 2022 | 08:58 AM
derekderek's Avatar
derekderek
i didn't read first post closely enough. new cam and never fired are different. maybe pull the intake and each lifter and add a good squirt of spread of assy lube to each lobe and lifter face. then make sure 1 is firing when you set dist to 1. (i hate dizzy) get it timed close. make sure you have coolant. and enough fuel. have it outside. and maybe get a set of inner valve springs and just run them for the break-in. that will also let you feel and check each valve for any too tight or too loose issues.
Old Sep 4, 2022 | 09:20 AM
mapman's Avatar
mapman
antevans245
From you post, cam is flat tappet not roller? Hydraulic or solid lifter? Lifter source?
Procedure you used to set valve clearance?
Did you use assembly GREASE on cam lobes or assembly lube?
Did you use assembly lube or engine oil on SIDES of lifters?
(Assembly lube is thicker and slows rotation of lifter on camshaft)
Perhaps as simple as distributor/wiring problem, but, a friend had similar EXPLOSION start issues that turned out to be wiped cam lobes. That is why I asked my questions above.
Mapman
Old Sep 4, 2022 | 09:23 AM
HeadsU.P.'s Avatar
HeadsU.P.
Screwing around with different valve springs would require more unnecessary turning of the crank to each cylinders TDC and a lot more work.
Post 1 says new cam. Why would you need to replace already?
I assume the engine never actually started. It would be almost impossible to wipe a cam lobe or lifter at cranking RPMs. It takes several minutes of run time for that to occur.
However, you don't want to remove any lube off of the cam right now.
Try to avoid turning the crank more than needed to get the IGN timing / valve-lash spot on.
Old Sep 4, 2022 | 08:02 PM
Rdavis's Avatar
Rdavis
Its been along time but if I remember correctly but if you set the cam up dot to dot, crank gear dot at 12:00 & cam gear at 6:00 this will be tdc for the compression stroke for #6 not #1. I believe your distributor is 180 out.
Old Sep 5, 2022 | 08:13 AM
derekderek's Avatar
derekderek
Correct. But much easier to be sure timing is not a tooth off. And many assume it is firing on 1 at that point.
To Engine backfiring after rebuilding top end
Old Sep 5, 2022 | 01:20 PM
Rdavis's Avatar
Rdavis
I learned about that as one of those "ask me how I know" things many years ago. I guess if a person has their heart set on dropping the dist. in on #1 they can roll the motor a full turn & it will be on #1.
Old Sep 6, 2022 | 09:32 AM
patdlangley's Avatar
patdlangley
I have done this before. It is real easy to get the distributor in 180 degrees out of phase.
I would just move the crank to TDC on cylinder one and check the rotor position. The problem is, you really need to watch the rocker arms to know when #1 is on the compression part of the ignition cycle. Knowing which wire goes to cylinder one, the rotor should be pointing to that plug tower on the distributor cap.
Old Sep 6, 2022 | 01:05 PM
derekderek's Avatar
derekderek
i think you can see #6 rocker or rockers through oil fill hole. if you go back and forth through tdc and the rocker moves-#6 rocker-you are firing on 1. if no rocker movement you are firing on 6. as far as the cam is concerned. pulling either valve cover is easier to be sure.
