Manual brakes to power
Its a numbers matching car so I want to keep it as factory as I can but the brakes could be better. The manual steering I can live with but though the manual brakes are adequate for everyday driving I’m worried that if the need for a panic stop comes up it will come up short. Seems everytime I take the car out someone feels the need to zip around me cutting it close getting in front. Tesla drivers mostly
it’s like they feel the need to prove something, ok whatever but I’ve had some close calls.
I try to just do my thing but the car is a magnet for it.I’m thinking that if I stay with proper ‘68 parts swapping over to power brakes wont hurt the cars originality or value. Am I right ?
I haven’t looked hard at the conversion yet but is it more that much more than installing a power booster and master cylinder?
I assume it is simple but since I’ve been wrenching this car I’ve learned Vettes have their own uniqueness and quirks to deal with.
The bolt holes in the firewall and the big hole needs to be enlarged.
To secure the new booster you will need a universal that is duct taped to stay straight.
You might need a different brake light switch.
It does seem that way when you compare the 68’s manual brakes to your new daily driver.
About the only true way to improve the stopping distance or quickness and efficiency of your brakes would be to replace the oem four piston calipers and 11” rotors all around with a set of larger six piston calipers in the front and four piston calipers in the rear, and increase the brake rotors to 14”.
This would increase the amount of contact or grabbing area on the rotors and greatly increase braking efficiency.
Wilwood has several package kits available that will fit with the oem rally wheels, or you can contact their customer service technicians who can help you build the right braking system for you needs.
The only down side is going with larger diameter rotors may cause you to replace the 15” rally wheels with 17” wheels and tires.
The plus side is no one would know you made any changes (if you choose an option which will fit with your rally wheels), and changing the calipers and rotors is all bolt on.
You wouldn’t have to drill any holes or make any modifications to your car that can’t be easily swapped back to the oem brakes.
I went with Wilwood’s D8-6 six piston calipers in the front and their D8-4 four piston calipers in the rear and will be replacing the oem 11.25” rotors with new 11.25” rotors.
I did a test fit and the new calipers and rotors will fit using the original rally wheels, however I did increase my wheel and tires to 17” so I can install better tires than those available in 15”.
As for the calipers the rear does have the 4 piston as did replace them with factory correct pieces. The fronts, I’m pretty sure they’re auto zone replacements which I’ll deal with this winter. One of the rear brake hose collapsed on me about 2 weeks back locking up the right rear caliper. New hoses in back fixed that and improved brake feel. I bought hoses for all 4 corners but haven’t done the front yet. I suspect that may improve the brake feel further yet. Perhaps semi-metallic or ceramic pads may help too.
The point about improved feel on the manual brakes is very valid. But realize that is most useful when you are threshold braking at the limit of adhesion, near 1G, preferably on a race track. Not something you do very often on the street. The quickest stop is when you have about 10% tire slip, just like in a turn, and you have to be able to modulate it precisely to hold it there. The power brake system has more hysterisis?. You can back off the manual system say 5% and feel the difference, where the booster "numbs" the feel down enough that you back off 10-15% before you feel the difference. So it is easier to hold the tires at their limit with the manual system. On the race track, where you might need to lose 60-80 mph, this could really matter. But in an autocross, where you just jab them for a sec, to scrub off 10-20 mph, not as much. On the street it would not matter at all, because you just do not (ever) brake that hard, to slide the tires.
But the manual brakes also require almost double the distance to move the brake pedal, to get the same amount of force. The smaller bore MC piston requires more stroke to move equivalent fluid. (The pedal movement specs were in the manuals somewhere). That takes time. The other thing is the manual brake sat higher off the floor on my car. I guess they all do? ( 2 year old Stone stock 75). I had to lift my ankle and leg off the floor to reach the pedal. On a power brake car the pedal was lower and my ankle can stay on the floor and just quickly rotate the foot over to the brake pedal. The difference in rection time will be substantial. On a race track it would not matter, because you are carefully planning exactly when you want to apply the brakes, so the extra pedal feel of the manual system would take precedence. But OTOH on the street, when some moron unexpectantly cuts you off, your reaction time to get your foot on the brake pedal and the pedal to floor will be much less with the power system. At a velocity of 88 ft per sec (60mph), even fractions of a sec will make a huge difference in impact distance. I would not care about the feel in a panic stop situation, I just want it on the floor, ASAP.
They each have their place.
…. Not something you do very often on the street….
Getting cut off by a moron whose mind is on anything but driving and anyone else is all too common as I live on the Jersey Shore. It’s that much worse during summer tourist season.
Driving a valuable classic thru summer traffic is like everyone else is behind the wheel of a bumper car.
I’m guessing I’ll take what I’ve got and make sure everything in it, every inch is as good as it was designed to be if not better with more modern pad designs available.
I appreciate everyone’s input on this and it greatly helps my decision making process. If I were more in the pines where traffic is low it wouldn’t be an issue. Here closer to the shore just taking the car the few miles from home thru beach traffic to Asbury Park to drive the circuit can rattle your nerves. Once your there your among car minded people and it’s a safe place but getting back home you have to drive thru the gauntlet of idiots again.
Oh ya, we are also heavy with deer out here.
Greetings from Asbury Park !
If you want to stay with stock components, you’ll need a lot more than just a power booster and master cylinder. You will need to change the relay rod, the pitman arm, obtain the power steering pump, steering cylinder, power control valve and related hoses, steering cylinder bracket, pump brackets, pulley and belt.
Know also that the factory power steering doesn’t have the best record. Fairly prone to leaks. The force exerted on the left frame rail from the steering cylinder is known to result in frame cracking.
A very popular conversion to power steering is the Borgeson unit. The downside to the Borgeson is you need to collapse the steering column ( effectively destroying the collapsible column safety feature).
I’ve got a bunch of vehicles new and old and even my Tacoma seems to hold the road better at speeds near 100.
I love these because they are brutal and primitive. The entire experience is exhilarating. Could use more from the brakes though.
This car has the HD 3.08 posi in it and from the power it puts out and what it’s tach’ing on the highway it feels like it’s quite capable of pinning the speedo.
Not with me driving it though . The guys who did that with these in factory trim on biasply tires back in the day were nuts !
I went the other way, from power to manual, and much prefer the feel of the manual brakes.
Bill
You have to cut and egg shaped hole in the firewall and the metal support is already shaped the way it needs to be so you can cut it easily with just a sawsall blade with out the tool. I have a small write up about it and you can find alot of how tos. The best bolt in master and booster combo I have used is made in the USA by Tuffstuff. You have to pay attention to the part number as the list them as 4 wheel drum, disc/drum and disc/disc.
https://www.summitracing.com/parts/t...ette/year/1968
you have to change the length of the pushrod that attaches to the pedal or buy the appropriate one
https://www.corvetteforum.com/forums...onversion.html
you should also have the power brake hole on the pedal arm as the manual brake is the top one and the power brake is the lower one i believe
