1980 Duntov Damage estimate Poll:
Old Jan 7, 2003 | 04:36 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default 1980 Duntov Damage estimate Poll:
What do you guys estimate how much the repair of my damaged Dunov Vert will be?
Pictures are in this thread:
http://forums.corvetteforum.com/zerothread?id=465875
[Modified by GrandSportC3, 4:36 PM 1/7/2003]
Old Jan 7, 2003 | 04:46 PM
Scott78's Avatar
Scott78
Default Re: 1980 Duntov Damage estimate Poll: (GrandSportC3)
I don't know if you ever saw my '78 Oliver, but I spin and hit a wall at 40 MPH.
Took a frame straightening session,Front and rear bumper and some fiberglass work with matching paint on repaired areas it was $6400. Yours looks as bad with a trailing arm damaged and a rim, is the wide body fender still available? I'd say if the fender is available your looking $7000-8000 with just painting the repairs. So I doubt they'll total it if the went that deep on my plain 'ol '78.
Scott
Old Jan 7, 2003 | 04:53 PM
GrandSportC3
Default Re: 1980 Duntov Damage estimate Poll: (Scott78)
Scott
Well - I wonder what is going to happen if the wheel and the fiberglass are not available anymore... :confused: :confused:
:cheers:
Olivier
Old Jan 7, 2003 | 05:26 PM
Scott78's Avatar
Scott78
I
That's where the biggest trouble would be is getting a fender to match or making a new one by hand. The rim might be a hard one to match too, might just have to get a whole different set.
I hope it turns out well for you.
Scott
Old Jan 7, 2003 | 05:41 PM
70 LS1's Avatar
70 LS1
I'm the 15-19 guy. I was in an accident 4 years ago in the 70. Damage looks worse on the Duntov and mine came to near $12000. You have a lot of specialized pieces there so I am going to guess around $16000. When do you get the estimate?
Old Jan 7, 2003 | 05:47 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 1980 Duntov Damage estimate Poll: (70 LS1)
ACI still makes those panels. http://www.acivette.com/index2.html It'd be a very nice buildup car for someone with some skills. It can probably be done for a few thousands if the frame is straight. Only problem would be that wheel, but there's a Duntov Turbo here in the Netherlands with the same rims (it's got black interior with wooden boards on the doors that say turbo)... think he would miss one rim? ;) :D Also, if the rim center is still straight a good custom wheel shop could probably fab some new rims.
Marck
[Modified by Twin_Turbo, 5:10 PM 1/7/2003]
[Modified by Twin_Turbo, 5:15 PM 1/7/2003]
Old Jan 7, 2003 | 06:00 PM
Wrencher's Avatar
Wrencher
We had a '70 BB in a body shop locally that I helped on that was hit hard in the same area. It was $3800.00 to install a one piece rear clip (Eckler's if memory serves), and then the guy had the whole car painted. With all the suspension bits and pieces it was $9800.- out the door. With a car as unique as yours, I would absolutely fix it. Barrett-Jackson has one listed (no reserve) in their guide for the auction this month in AZ. See what it goes for and then decide.
http://www.barrett-jackson.com/event...es/allcars.asp
Hans
[Modified by Wrencher, 3:02 PM 1/7/2003]
Old Jan 7, 2003 | 07:03 PM
GrandSportC3
I
Scott
Different wheels would reduce the value of the car and would be unacceptable for a car that rare...
Old Jan 7, 2003 | 07:05 PM
GrandSportC3
The adjuster is going to look at the car tomorrow morning... He will probably have the numbers shortly after...
:cheers:
Olivier
Old Jan 7, 2003 | 07:45 PM
Toy4Two's Avatar
Toy4Two
I'd stick to my guns and make sure they do it right, and with the right pieces. And to do that, will be some major dollars, so hopefully "IMO" they total it and hand you a VERY VERY large check!! :yesnod:
Maybe this poll should be,
How much do you think the insurance company will offer me?
First offer:
$8500.00 :eek: :sad:
Then it's a :boxing match!
Good luck, I wish you the best! :cheers: :cheers:
[Modified by Toy4Two, 12:49 AM 1/8/2003]
Old Jan 7, 2003 | 08:21 PM
backtrail69's Avatar
backtrail69
St. Jude Contributor
im sorry
Old Jan 7, 2003 | 10:08 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: 1980 Duntov Damage estimate Poll: (backtrail69)
I'd guess around 10k to fix it, but I'm no expert.
Old Jan 7, 2003 | 10:37 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
I'm thinking this will run into the $17-17.5K range. If it were a regular Corvette , probably in the $12K range.
It will be extra for the rear fender and especially the rear wheel :yesnod:
I wish you the best of luck with the adjuster tomorrow. :thumbs:
:seeya JRD77VET
Old Jan 8, 2003 | 03:02 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Default Re: 1980 Duntov Damage estimate Poll: (Toy4Two)
First offer:
:iagree:
Olivier...I know you are worrying like crazy about this. It's hard to put oneself in your place. I would be worried sick, even with insurance.
You know what my suggestion is...take the check...build a ZL-1...and drop in into your other car. I think you will quickly forget the wrecked one when you are smoking the tires with that ZL-1. :thumbs:
Hang in there pal...it will get better.
Dep
Old Jan 8, 2003 | 12:47 PM
GrandSportC3
Just called the Adjuster from the insurance.. He hasn't looked a the car so far.. He said that he is on the way to the car right now.. So - hopefully I will have numbers in a few hours...
:cheers:
Olivier
Old Jan 8, 2003 | 02:03 PM
Toy4Two's Avatar
Toy4Two
Good luck :thumbs: :thumbs: :thumbs:
Old Jan 8, 2003 | 03:03 PM
GrandSportC3
I just got off the phone with the guy from the bodyshop.. He doesn't have the exact numbers but he said that it will be in the neighbourhoud of 10k... So - let's wait for the exact number.. (They didn't consider the damaged dash).. I called them and told them about the dash..
:cheers:
Olivier
Old Jan 8, 2003 | 03:14 PM
Sting Raycin's Avatar
Sting Raycin
Whatever it cost, it's not going to be cheap. LEt us know how it goes.
Old Jan 8, 2003 | 03:18 PM
theandies's Avatar
theandies
I didn't vote in you poll because its just too hard trying to estimate damage by looking a pictures. As rare as your Duntov is, even if they do total it, buy it back and get it fixed. I know you are "garage challenged" but just rent one of those storage rooms if you have to. I would also check the Barrett-Jackson auction and see how much they get for the Duntov mentioned above. That may go a long way in helping you make your decision. Good luck and don't let the insurance :reddevil man bite.
John
To 1980 Duntov Damage estimate Poll:
