After changing the differential fluid yesterday....
Old Jan 8, 2003 | 10:07 AM
kgraumann's Avatar
kgraumann
Default Re: After changing the differential fluid yesterday.... (GrandSportC3)
Where can I get the posi lube?? I went to some parts stores and didn't find it...
Ecklers has it:
http://www.ecklers.com/product.asp?p...N0SM2EPKXK06QD
I just get mine from the Chevrolet Dealer here, most will keep it in stock.
Old Jan 8, 2003 | 10:09 AM
Twin_Turbo's Avatar
Twin_Turbo
New posi fluid as in oil with additive or just plain gear oil????
Old Jan 8, 2003 | 10:13 AM
69er's Avatar
69er
Active Streak: 90 Days
Default Re: After changing the differential fluid yesterday.... (Twin_Turbo)
4 ounce bottle of posi additive.
Some say use one...some say use two bottles.
I used synthetic gear oil of which the additive is not needed but put a bottle in just in case.
A little trivia?
I've heard years ago GM posi fluid was whale oil and was better than today's version.
[Modified by 69er, 10:16 AM 1/8/2003]
Old Jan 8, 2003 | 10:18 AM
page62's Avatar
page62
Chevy dealer. In fact, that's where I'm going this morning to get a bottle of posi lube and 2 qts of diff fluid! :yesnod:
I'm sticking with dino fluid until I feel like tearing the rear suspension apart to get at the diff cover to replace the leaky gasket.
Old Jan 8, 2003 | 10:20 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: After changing the differential fluid yesterday.... (69er)
Dunno if that's true about the whale oil but the GM stuff sure stinks though if it's bad and should've been changed a long time ago
[Modified by Twin_Turbo, 9:23 AM 1/8/2003]
Old Jan 8, 2003 | 10:23 AM
kgraumann's Avatar
kgraumann
A little trivia?
I heard it was whale oil, matter of fact, I think I read it somewhere. Don't remember where though.
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: After changing the differential fluid yesterday.... (groovyjay)
Well I did it at the mall and got stopped by the police. Made me get out of the car, searched me, asked me if I was on drugs!!!
Well... were you? :lol: :lol: :lol: :lol:
NO!!!!
The two cops said they could give me a reckless ticket. Geez. Deserted parking lot, no squealing tires, just going in figure 8's. :rolleyes:
Old Jan 8, 2003 | 10:27 AM
69er's Avatar
69er
Default Re: After changing the differential fluid yesterday.... (kgraumann)
A little trivia?
The shop owner who rebuilt my rear told me about the whale oil.He said today's GM posi stuff isn't as good but does the job.
He said he would buy all he could if he found a source.
He also said if iI should ever see the old stuff at a garage sale or such buy it.
Old Jan 8, 2003 | 10:45 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Ecklers and others.
GM Dealer parts dept
Auto part stores carry a different brand posi fluid.
Some say it's the same as GM....some say it's different.
Unless you used synthetic fluid you need the posi additive.
Well - I used Mobil 1 synthetic differential fluid.. Does this mean that I don't need the additive???
:cheers:
Olivier
Old Jan 8, 2003 | 10:53 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What type of fluid did you use? When i changed mine a while back I refilled it with some nice Mobil 1 synthetic gear oil and two bottles of posi additive. Did you crack the differential seal or pump out the old fluid?
Mark B.
Old Jan 8, 2003 | 10:58 AM
69er's Avatar
69er
"Well - I used Mobil 1 synthetic differential fluid.. Does this mean that I don't need the additive???"
Olivier
I can only speak of Amsoil synthetic rear oil.
I called Amsoil and was told there is no need for the posi additive but I could add it if I felt more comfortable by doing so.I added a bottle.
I imagine Mobil 1,Castrol,Redline etc. would be the same.
[Modified by 69er, 10:59 AM 1/8/2003]
Old Jan 8, 2003 | 11:15 AM
GrandSportC3
Olivier
I might call Mobil and ask...
:cheers:
Olivier
Old Jan 8, 2003 | 11:16 AM
  #33
GrandSportC3
Default Re: After changing the differential fluid yesterday.... (Sigforty)
Mark B.
I used a pump..
The fluid was Mobil 1 synthetic 75W90 differential fluid...
:cheers:
Olivier
Old Jan 8, 2003 | 01:24 PM
  #34
Twin_Turbo's Avatar
Twin_Turbo
You always need the additive. It's GM's "fix"for chirping rattlijng rear ends. In the beginning the stuff wasn't added and there were a lot of complaints. The noise was tracked down to too agressive grabbing of the clutches and so they added the additive to allow some slippage. Without it your rear will almost always clunk, chirp whatever.
Marck
Old Jan 8, 2003 | 01:41 PM
  #35
GrandSportC3
Marck
Thanks!!! I will get the additive!!
:cheers:
Olivier
