Hole under fuel pump mount
Old Sep 26, 2022 | 09:30 AM
kellsdad's Avatar
kellsdad
Default Hole under fuel pump mount
I saw a related earlier thread but decided to start a new one for my question.
I have a 2001 vintage GM 350 crate engine in my C2 Corvette. While checking it for an minor oil leak I noticed the hole beneath the fuel pump mounting block. This photo of someone else's engine shows the location.
The earlier thread mentioned this hole being threaded for a bolt. On my engine, which has never had a mechanical fuel pump, the hole appears to have something similar to a freeze plug inserted. My inspecting showed a small fractured hole at the top of that plug. That leaves me with several questions.
  1. First, what might cause that hole?
  2. Second, how is the plug removed?
  3. Third, how is a replacement plug installed?
  4. Finally, would a hole in that location cause a large oil leak? I ask because any leakage appears to have been small.
Old Sep 26, 2022 | 04:46 PM
kellsdad's Avatar
kellsdad
My research has yielded what sounds like the answers to my questions. A local source identified that hole as one used to help when installing a mechanical fuel pump. As my crate engine came from the factory without a mechanical fuel pump, that hole, which is normally tapped and plugged with a short bolt, was left untapped and filled with a plug. To fix mine I'll need to remove the plug, tap the hole and install a short bolt.
Old Sep 27, 2022 | 02:41 AM
carriljc's Avatar
carriljc
I'm thought the hole for holding the fuel pump pushrod is in forward facing surface not underneath??
To Hole under fuel pump mount
