No "check engine" light to see what is wrong
About year ago, as I was pulling out of the neighborhood, it just died. Waited about 2 minutes or so, it fired back up and I limped it home, took a few start/stops, but made it. Figured it was the fuel pump, so I replaced it with ACDelco EP241, for more fuel pressure.
Have driven it various times over the year, not much, maybe once/twice a month, but never had any problems. It would start right up and cruised along, no issues. The last time it was on the road, it drove fine, no issues, drove it around and then parked it in the garage. Then week or so later, hoped in to take it for a spin and it died backing out of the garage. I figured that it must be the fuel filter, so I replaced that. Now the car is acting differently
2. Next day, fired up the car and let it idle for about 10-15 minutes. Shut off the car and then tried to restart it. It wouldn’t restart normally. When I finally got it restarted, it was running really rich, the exhaust smell of gas was pretty potent.
3. Day after that, it fired up fine, no bad gas smell, but stalls when put it in gear.
If I jumper A-B on the ALDL and I get no blinking, not even the “12”. I can hear something clicking when I add/remove the jumper, so at least I know my jumper wire is making contact with the terminal pins. The manual (page 6E-21) says check Circuit 419. Is there an easier way to get to Pin 20 on the ECM connector then becoming a contortionist and trying to get visibility to the connector. I am half temped to pull the passenger seat to make getting to the ECM connector easier.
I want to see if the ECM is throwing any codes, before I just guess and start replacing the oil pressure switch, the coolant switch, and other various things I have seen mentioned in various posts, it would be nice to know what the ECM thinks is wrong. Is there any test connections points inside the engine compartment. It would be nice to test the various sensors under the hood, then determine if there is a wiring issue.
Also, is there a fairly inexpensive code scanner, that can connect to the ALDL, instead of using the check engine light? I don't want to spend $2K on something, but couple hundred on a decent reader might be worth it.
Someplace to start checking.
I think I figured out that the "Diagnostic Check Connector" shown on page 8A-87 of the service manual is the ALDL port, under the ashtray. If that is the case, I should be able to take pin C to ground, and the Check Engine Light should turn on. If I can toggle the engine light manually, then that kind of leans towards the ECM not controlling the light, which is bad.
There is no good way to get to the CEL bulb without taking half the car apart, but when I put a test light on circuit 419, it does turn on when I turn the ignition on, then goes back out after the car has started. So at least the ECM is controlling the light circuit. The test light wasn't as bright as when I tried it on the cigarette lighter, just to make sure that I had a good ground connection. Jumping ALDL pins A & B didn't get me any flashes with the test light on Pin C. I would have though I would have got the 12 code, but trying to get jumpers and test probes through the ashtray opening, I might not have made good connections. I will try using the scanner, when the GM-1 ODB adapter comes in on Monday.
I guess this weekend’s project is taking apart the center console to get to the CEL bulb, and replace that. Then we are back at square one.
However, I noticed that there is some gaffers tape covering one of the traces for the oil temperature light. I created another topic, Console circuit board since this topic was concerning the CEL.
Two things do bother me though:
1. The scanner is telling me that the ECM is in “Limp mode”
2. The ECM is staying in “open loop" mode, unless I get the RPMs up to around 2K. Maybe I need to let the car warm up for 10-15 minutes and see if that helps.
Been trying to find any information about limp mode and what could cause that. I get no codes on the scanner, or counting the CEL blinks. Not sure how it decides to go into limp mode, and what needs to happen, to get out of that mode.
A review by you is liked.
More info would be nice, when you solve your issue, like fuel ratios and timing advances.
thanks
the .46V instead of .525 is very minor and not hurting anything so don’t waste time , if voltage goes up nice as you floor it then you’re done with the TPS
dead or lazy Oxygen sensor is what causes the vehicle to be in Open Loop or have to rev high to get to closed loop
When in Closed Loop you should see the 02 swing back and forth from low voltage to high voltage with lots of Cross counts if working correctly with a good O2 sensor
When I worked at GM I found an engineer that worked on the Crossfire and he recommend the Peerless 350. I found one cheap on e-bay. Perfect condition but no instructions. Still don't know how to use all the features but it reads the basics just fine.
