Totally Tubular??
Old Oct 1, 2022 | 07:10 AM
The Phantom's Avatar
The Phantom
Default Totally Tubular??
Front Tubular "A" arms, much of what you read says they are all the ones you need, so all you members that are running them, who's are the street arms I should run? I have the coil overs in place and stock poly bushed "A" arms, so the bones are there just need to finish things up. This is a mostly street use car that will see some spirited driving and an auto cross or two.
Inquiring minds want to know?
Dave
Old Oct 1, 2022 | 12:41 PM
sunflower 1972's Avatar
sunflower 1972
I used Ebay arms for 58 - 64 Impalas. No "Corvette tax". They're usually manufactured with an additional 4* of positive caster. But, they require a few minor modifications. Here's the thread detailing the modifications but, it's very long: https://www.corvetteforum.com/forums...ar-a-arms.html
Old Oct 1, 2022 | 06:07 PM
Crimson Thunder's Avatar
Crimson Thunder
I'm going with the Global West control arms when the time comes.
Old Oct 1, 2022 | 06:14 PM
The Phantom
An interesting option.
Are global west better than others? Is it the price, or performance? What lower would you use, the standard or extended travel for the extra $10.?
Dave
Old Oct 1, 2022 | 07:48 PM
509 rat's Avatar
509 rat
spc is the only way to go period .
Old Oct 2, 2022 | 11:11 AM
sunflower 1972
Dave
ONLY $598.75 FOR A PAIR!! IMO, that's just obscene.
Old Oct 2, 2022 | 11:24 AM
cagotzmann's Avatar
cagotzmann
Dave
SPC give you the best of both worlds.
Specialty Products Company | SPC Alignment | The Automotive Alignment Leaders
#1 adjustability. This is the only good way to get max caster setup without giving up any other adjustments. Shim / slotted a-arms only goes so far.
#2 Tubular arms with bushing that support from street to full race.
I have been running SPC since 2012 and mainly use the car for track days.
Old Oct 2, 2022 | 04:15 PM
Crimson Thunder
Dave
I like the Delrin bushing that the Global West has. I would go with the extended travel but I have QA1 coil overs.
Old Oct 4, 2022 | 09:22 PM
The Phantom
Adjust-ability is great, so what lower arms are you running with these uppers? I don't see lowers offered here, or did I miss it?
Dave
Old Oct 4, 2022 | 11:45 PM
forman's Avatar
forman
do the ones from ebay need to be modified
Old Oct 5, 2022 | 07:27 AM
c66vet's Avatar
c66vet
If your considering Global West upper control arms, be advised that they are almost an inch wider than the stock upper control arms. This is due to the width of the Delrin bushings used. There have been some posts where users have had to modify their headers, cut fan shroud for clearance when using global west upper control arms.
Old Oct 5, 2022 | 08:15 AM
The Phantom
Info that I had not seen yet, thanks. The fan shroud would not be an issue but I am currently running Hooker side pipe headers.
Dave
To Totally Tubular??
