Removing clock on 69 convertible
Old Jan 8, 2003 | 07:33 AM
klasik69's Avatar
klasik69
8th Gear
Default Removing clock on 69 convertible
I'm having a hard time pulling the radio/gauge cluster out to get to the clock on my 69 because I can't get to the two back studs holding the radio onto the console frame. Shop manual says use a flex drive from side after removing side access panels. I can get a finger up there but can't get a socket on the nut, which I think is a 10-32 nut. Can it be done by removing console cable control & accessing it that way ??
Old Jan 8, 2003 | 07:53 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Removing clock on 69 convertible (klasik69)
The radio itself is held to the gauge bezel by the ON/OFF and TUNER switches, and one nut on the passengers side. That's all that holds it in. After disconneting these 3 things, you should be able to wiggle the radio out from the passengers side. If you're trying to get to the 2 nuts that hold the gauge bezel to the console, they are a PIA. Can't tell you any tricks other than to keep trying. Might be easier with the radio out first. Chuck
Old Jan 8, 2003 | 08:30 AM
30yr Wait's Avatar
30yr Wait
I agree. They're really hard to get at, but it can be done.
I used wing nuts when I put it back together. Hopefully make it easier the next time
Pat
To Removing clock on 69 convertible
