You can buy blades or refills from your local AP store.
Trico blade and refill #16-2 These are low profile and fit under the hood.
Refill only Trico #43-160
Don't overthink this. Those $40 refills are for the guys showing the cars. If you want to drive it, you can get many parts at the local NAPA, O'Reillys, Autozone, etc.
Keep the package and your receipt. While the blade length is easy to measure, the actual height of the metal “Frame” can cause problems. Look at what you have, if they don’t hit anything, then try and get the same type/style frame. When I had my windshield replace the wiper blades on my 73 hit the hood. I took the car back to the glass shop and they were stumped. I ended up getting new blades with frames that are very small. Go figure?
