Differential Half Shaft Circlips
Old Oct 21, 2022 | 12:38 PM
71 Corvette's Avatar
71 Corvette
Default Differential Half Shaft Circlips
My belief is that the circlips that retain the half shafts in the differential are there to facilitate production assembly only and serve no other purpose. Is this correct or is there some other performance aspect?
Old Oct 21, 2022 | 12:59 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Are you talking about the clips on the stub shafts that connect to the half shafts? If so, those clips are to retain them in the differential and into the posi unit. The posi gears and even the clutch disc are splined to those stub shaft axles.
Old Oct 21, 2022 | 01:36 PM
71 Corvette
Thank you for the quick response. When I was attempting to remove some of the rear suspension parts the half shaft came right out of the differential, It slides back in once you get the splines aligned. it just doesn't seem right that you can slip it back in and it will all work properly.
Old Oct 21, 2022 | 01:48 PM
71 Corvette
Forgive me but I do not understand. If I remove the differential cover and find and remove the circlip can I just slide the half shaft in and all will work as new?
Old Oct 21, 2022 | 02:27 PM
69L88's Avatar
69L88
What likely happened is either: a) the clip fell out inside the differential or b) the axle tip has worn down past the circlip groove. You need to pull the differential and look inside.
Old Oct 21, 2022 | 03:10 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The halfshaft is part of your suspension locating point. Without the clips the wheel assembly can move all over the place and pivot off the lower strut rod.
You CAN leave off the clips and let axles float IF you add an upper link arrangement to the trailing rams to locate it. In that case you remove the clips so you don't put it in a bind.
JIM
Old Oct 21, 2022 | 05:16 PM
Sigforty's Avatar
Sigforty
You should be able to if the groove for the clip is still there. You might want to look and make sure the clip didnt mess up anything inside if you can find it. I would listen to check what 69L88 said above.
To Differential Half Shaft Circlips
