75 Vette keeps shutting down completely.
Old Oct 23, 2022 | 10:35 AM
Mouselady2004's Avatar
Mouselady2004
3rd Gear
Default 75 Vette keeps shutting down completely.
Where are the hot wire fuses around the motor located?
Old Oct 25, 2022 | 12:33 PM
MelWff's Avatar
MelWff
Not sure what you mean by "hot wire fuses".
There is only one fuse box, drivers side under dash.
Do you mean fusible links?
If so, starter harness.
A better description of problem would help.
Old Oct 25, 2022 | 06:36 PM
kansas123's Avatar
kansas123
One fusible link at the starter, one near the horn relay. Thought there was another one but can't remember for sure. Should probably check the ground cable from the battery to the frame below battery box. They have a tendency to corrode at the connection.
To 75 Vette keeps shutting down completely.
