What determines if you need an intercooler?
What's the determining factor as to when/whether you need one?
Any intercooler on a Roots blower will need to be sandwiched between the blower upper assy and the lower assy., which will increase it's overall height, which will require either a big block/custom hood, or cutting a hole in your hood.
If you are running somewhere near 5 - 7 pounds of pressure - No worries......
Since posting my question I read that the air-fuel flow on a carb'd setup also has a cooling effect.
OT question for you - Is the build date on your 'Vette close to your Birth Date. That would be cool......
My gut feel is that 6lbs on 93 octane may be ok in most cases. 14lb on pump gas is risky without intercooling IMHO. Not saying it can't be done, but I wouldn't. Also 14psi for a short blast is not the same as 14PSI on a quarter mile.
WW fluid is cheap, and in every parts store, and gas station. The benefits to using it are two fold, not only will it cool the intake air charge, but the meth mixture effectively increases the octane, which reduces chances of detonation. As long as you have an air cleaner mounted on the carb, so that it could be misted into the space above the carb, you have a way to inject it.
There may be kit manufacturers making a base plate injection kit like a nitrous plate as well.
Whether or not 6 pounds of boost makes it a required mod, there is significant evidence of the torque gains that come from using a kit like this on a roots type blower. I can’t say if it’d help that much at 6 psi, but it certainly wouldn’t hurt.
https://www.lxforums.com/threads/met...76765/?u=31470
I am not using any type of Turbo or Supercharger but still have an application where the water/methanol injection system really helps the engine. I have a L88 Replica engine running the 12.25-1 Compression ratio and most of the year it works without any help but the Water/methanol injection can save your engine. The extra water is used in the combustion cycle and helps pull heat out of the combustion chamber as it converts to steam and the methanol hives your fuel a serious boost in octane. It is able to make 93 Octane into 116 octane which slows down the burn time and prevents detonation.
The injection system works great and in the end replaces the need for any kind of special fuels. It even works better than the Aviation 100 Octane Low lead gas I tried for a while. With the leaded fuel I started seeing lead building up on the crowns of the pistons. Using the water/methanol injection system the combustion chamber stays nice and clean and the controller only activates it when under a load.
There are several companies making the water/methanol injection systems and most are for turbo or super charged vehicles where there is no room or money left for an inter-cooler.
Intercooling/aftercooling isn't to compensate for other conditions. Its about increasing air density to pack a greater mass of oxygen into the cylinder so you can burn more fuel to make more power. The goal isn't pressure, it's air mass.
