im trying to get the bugs out of my heat a/c . is the fresh air intake door located in the passenger side wiper well supposed to close when the a/c is put in MAX(recyle) mode?(green stripe vaccume line) also closing the air inlet valve at passengers feet(orange stripe vaccume line) im trying to determine if i have a bad vaccume selector control valve in the selector switch-- this door slams shut when i apply sorce vaccume to it, so i know the diaphram is working--besides this problem i've noticed that when going to defrost ,the air still comes out of the ***** on the sides and at the floor-telling me these diaphrams are not working or bad vaccume selector - testing vaccume selector today- just wanted to make sure i had the function operation correct .........................thanks--carl
thanks for the web site it helped out- problem was a badCLIMATE CONTROL ROTARY VACCUME SWITCH-9 PORT-$19.95- FOR ONCE IT WAS THE CHEAP WAYOUT!!- made a vaccume jumper out of 1/8'' vaccume hose ans 1/8'' plastic coulpings pulled the vaccume lines off the heater-a/c switch and jumpered 1 at a time,, black is sorce vaccume- .as i jumpered to each different color striped vaccume line the acuator would pull in ---now i know all the acuators work(and thanks i didnt evem know there was one above the gas pedal for defrost/heat mode)-- now all i hope is that once the part is installed- i get good air flow to that function-(say defrost) because the way it was air was going allover the place instead of being directed where i wanted it to go- thanks again-carl--- http://www.geocities.com/carlclub2/
