Block identification
Old Nov 14, 2022 | 07:29 PM
Crazywillie1's Avatar
Crazywillie1
7th Gear
Default Block identification
Ok. I need Help , been a Shade tree Chevy guy for 50 yrs ( I’m 60) , built several hot rods , to many to remember , nova’s , Camaro’s c10’s , even some Corsair’s showed them all ( never found a vette I could afford ) anyway had a stoke , doc told wife to sell them all . Long story short , I haven’t really turned a wrench in 10 years , month ago Jr , says Dad , wish we woulda built a car together , kinda stuck in my throat , so I saved my my 300.00 a month my wife says is enough , so I saved , found a 1948 Chevy StyleMaster, Guy says cut ya a deal , 1,000 for the car 100.00 to deliver , 80 miles ) I got a deal frame off 4 way link rear suspension, mustang 2 rack and disc breaks , floors already done , any way I found a guy giving away a 327 ci said it had been in his garage for 30 years , ( I’ve even already bought a trans ) . So I went and got the 327 for free FREE , IM TRYING TO IIDENTIFY THE BLOCK . CM 3914660 appears never been planed as stamped number still in front of number 2 cylinder are TI 024EE , 18L316 I think 990 . Need help
Old Nov 14, 2022 | 07:35 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome to the forums, moved you here to other cars.. Do you know maybe the year of Corvette motor is from?
Old Nov 14, 2022 | 07:37 PM
Crazywillie1
7th Gear
Told 1968
Old Nov 14, 2022 | 08:21 PM
kkupec02's Avatar
kkupec02
welcome
Old Nov 14, 2022 | 09:48 PM
Gixxerman's Avatar
Gixxerman
Moderator
If it is a 1968 Corvette engine I can move you to that section
Old Nov 14, 2022 | 10:35 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Preliminary sleuthing shows it was cast and assembled at the Tonawanda engine plant (T) on October 24 (I024) for installation in an auto trans El Camino, Nova, or Chevelle. No Corvette small blocks were cast at Tonawanda, only big blocks. I didn't investigate the VIN sequence to ID the model intended for, but I believe the 8 in the VIN indicates 1968.
From the Lime Book (link in the forum stickies):
Old Nov 14, 2022 | 11:29 PM
Crazywillie1
7th Gear
thanks for getting back . So the cast 3914660 come up vette but it’s not . I don’t really car just trying to figure out what I got to order internals . Is it 69 then it’s large journal . As 67!was small journal crank Ugg is the double chain time set a stock item . And double hump heads . Just trying to find out if factory or someone’s toy
Old Nov 15, 2022 | 06:10 AM
Crider's Avatar
Crider
Does the block have the extra hole in the rear, for a road draft tube and a bolt on oil filter? If so it is going to be a small journal block. No draft tube, and spin on filter will be a large journal.
Old Nov 15, 2022 | 06:15 AM
Mr D.'s Avatar
Mr D.
Chevrolet by the Numbers by Alan L. Colvin
Block casting 3914660 is identical with the 39114638 except for minor interior casting changes at the bottom of the cylinder bores for rod clearance. It was used interchangeably with the 3914636 in certain applications, but they are unverified at this time. Those applications which could have used this block are listed above. There was some evidence that this block was used prior to February 29, 1968 assembly date. Note: All applications have not been verified.
1968
Passenger / 327 / 250, 275 hp / 2-Bolt
Chevelle / 327 / 250, 275 hp / 2-Bolt
Chevy II / 327 / 275 hp / 2-Bolt
Camaro / 327 / 210, 275 hp / 2-Bolt
Corvette / 327 / 300 hp / 2-Bolt
What you have is a 1968 327 block with large main journals.
If that engine was out of a 1968 Corvette the pad would read FXXXXHE, HO, HP or HT.
Engine suffix code EE for 1968 is:
Chevy II / 327 / 275 hp / Powerglide
Chevelle / 327 / 275 hp / Powerglide
Camaro / 327 / 275 hp / Powerglide
What are the cylinder head casting numbers, I'm guessing 3917291.
Old Nov 15, 2022 | 06:53 AM
mapman's Avatar
mapman
Crazywillie1
Could you post a photo with scale and coverage similar to photo #3 in John Hinkley's article on small block production. (Link below)
I am curious about what appears (out of focus) to be a square plug on your motor's front.
Thanks. Mapman
http://www.camaros.org/pdf/flint_engine.pdf
Old Nov 15, 2022 | 10:07 AM
Hopper12's Avatar
Hopper12
Double roller chain is not a stock item. Lots of great help on here. I wish you well with your build! Best, Paul
Old Nov 15, 2022 | 02:25 PM
Crazywillie1
7th Gear
1968
where are head casting numbers took a quick glance , but didn’t see them
Old Nov 15, 2022 | 03:49 PM
Mr D.'s Avatar
Mr D.
Underneath the valve cover stamped on the head.
Old Nov 15, 2022 | 04:07 PM
Crazywillie1
7th Gear
Thank you
Old Nov 15, 2022 | 07:21 PM
stingr69's Avatar
stingr69
My guess is "291" heads.
Old Nov 15, 2022 | 10:39 PM
Crazywillie1
7th Gear
LolThats funny . I got mine it was a frame off it’s the body and missing parts anf glass
Old Nov 16, 2022 | 12:47 AM
Crazywillie1
7th Gear
Hey guys , I bought a supposed to be runner 305 not sure of year yet as paid but not home , what dam spark plug does it take . At least with old 327 j12y works , and for yer lawn mower lol
Old Nov 16, 2022 | 05:52 AM
Mr D.'s Avatar
Mr D.
Rock Auto says AC DELCO 19208523
To Block identification
