Car squeals and dies
Old Nov 18, 2022 | 11:12 AM
Jd21476's Avatar
Jd21476
Default Car squeals and dies
I have a 1968 with a 383 Stroker, Holley Sniper efi and MSD ignition. I started the car yesterday and i had a terrible squeal coming form under the hood that got worse as I rev'd it but then subsided as it got warmer. I took it for a quick drive and she seemed to run fine. I let it sit over night, got back in today and she will start right up but then within a few seconds the squealing starts and she dies. Almost as if she is starved of fuel but I can hear my electric fuel pump run and my fuel pressure is good. My alternator is only about a year old. Any ideas?
Old Nov 18, 2022 | 01:15 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would determine if its a belt squealing and if its squealing because its loose. If its tight then you may have a bearing going in your alternator or PS pump. The dying right away may or may not be related....you may need ot ensure you are getting fule flow or maybe your floats are stuck and its not getting enough fuel....maybe squirt some fuel down the throat and start it and see if you can keep it running,,,,check the fuel bowls sight glass if its a holley...
Old Nov 18, 2022 | 01:19 PM
Jd21476's Avatar
Jd21476
Its the Holley efi system so I not sure if I can squirt fuel straight into the bowls. There are no floats.
Old Nov 18, 2022 | 06:06 PM
Jd21476's Avatar
Jd21476
I wonder if my alternator died and that is the squealing. It would also justify the fact that the car dies cause my MSD and Holley are not getting enough from the battery.
Old Nov 18, 2022 | 10:48 PM
Rescue Rogers
That makes sense. I know my EFI got all weird when my battery was bad and it was living of the alternator....good direction to investigate
Old Nov 19, 2022 | 05:19 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your EFI should run fine down to about 7 volts. Maybe high 7 volt, like 7.8 volts or so. If your car is turning over I'll bet you have way more than that. But your aftermarket EFI may be more touchy than a factory Dephi setup. I have no way to know.
The squealing sounds like belt slipping. Bad, worn, loose belt or bad bearing in your Alternator???
Is one related to the other? Seems a strange coincidence that both happened at the same time.
Find the squeal! Hopefully you'll find all the trouble.
Old Nov 19, 2022 | 07:23 AM
Rescue Rogers
No it will not run fine below 12 volts, Holley actually states that in one of its troubleshooting videos.
Old Nov 19, 2022 | 07:43 AM
Rescue Rogers
I would get the squeal taken care of, make sure your alternator is working correctly then look through these posts to see if any of these hold your answere. It appears there is a relay control that cuts the fuel pump.
https://forums.holley.com/forum/holl...ire=#post62072
Old Nov 19, 2022 | 07:47 AM
Rescue Rogers
EFI sytem pro tips
https://www.efisystempro.com/efi-pro...olley-tom-kise
Old Nov 19, 2022 | 08:18 AM
Bikespace's Avatar
Bikespace
Do you have a multimeter? Or a cell-phone charger with a voltage display that plugs into your cigarette lighter?
Another possibility: Take the belts off and check that the accessories spin. A car I once had came with a frozen AC compressor, and wouldn't run. Easy fix, once I found someone to extract the R134a.
Old Nov 20, 2022 | 10:17 AM
Fredric Björnefält's Avatar
Fredric Björnefält
Sounds like Alternator belt, ps belt or water pump..
Old Nov 20, 2022 | 10:26 AM
carriljc's Avatar
carriljc
I would remove the alternator belt, use jumper cables from another car (to maintain voltage), then start the Corvette to see if 1) it no longer squeals, and 2) it no longer dies.
If it still squeals then remove the other belts (assuming you have multiple belts).
That should knock off a bunch of troubleshooting and it's quick and relatively painless.
To Car squeals and dies
