TKX 5-Speed for '69...
In my quest to throw even more money at my '69 vert restoration, I've been considering replacing the original Muncie 4 speed with the TKX 5-Speed. I really like the fact that with .68 top gear, you can drop those freeway cruising RPMs down pretty considerably - around 32%, which is significant. Anyone here done this conversion on a C3, and if so:
How do you like it compared to the M20 or M21?
Was the installation direct-bolt in as they say, and without tunnel modifications?
Research is telling me it is not a direct bolt, although no cutting seems to be necessary
Doesn't look like you can use the original driveshaft. Researching this, it looks like you have to shorten the driveshaft by about 2.5"
Input shaft is fine spline as opposed to the course spline, so you have to use a late C3 Corvette clutch
The Yoke needed is a 31 spline, so you cannot use the OEM 27 spline yoke.
What if you want to maintain mechanical linkage? Any issues? - If I end up doing this conversion, I'd prefer to not convert to hydraulic clutch.
I'll be running a SBC stroker rated at about 425/450tq, and these are supposed to be rated at 600 ft lbs.
I'd love to get input from anyone who has done this conversion.
Input shaft is fine spline as opposed to the course spline, so you have to use a late C3 Corvette clutch and pressure plate
- I purchased a Kit. Included driveshaft, speedo cable, and all necessary hardware to install.
- Purchased only clutch disc, used my existing pressure plate.
- Used my existing clutch linkage.
- No cutting of anything required.
- It IS a direct bolt in.
I've had no issues at all with the transmission since installed. BE SURE to index the bell housing.!!
A friend has a TKO 600 installed in his '74, stroker 383, best run, on engine dyno, was 502 hp. He has had it on the track a few times, best at 11.91.
I had not heard of anyone not liking the upgrade to a 5-speed.
If I were doing it over, I might consider the .72 or .81 overdrive. The drop to the .68 overdrive is substantial. It's more of a 4-speed with overdrive than a 5-speed trans. It works great for highway cruising economy, but you don't drive it like a true 5-speed. Adding the 5th gear makes all the difference. The car is now a joy on the highway. Before, it was just a pain.
I had my 68 crossmember sectioned as shown in the second photo. A really great mod to make tranny install/removal much easier.
My TKO-500 with a 3.73:1 nicely drops engine revs when cruising on the freeway. Like the TKO shift...very neat and crisp. Seems like you can just about do the shifting with your wrist.
Bought my TKO-500 as a kit...included the drive shaft and hardware. I think I had to buy the clutch disk separately. Had it installed by J&D Corvette in Bellflower, Ca. They did the cross member modification also.
The big cammed 355 didn't like loafing along at 1900 RPM at 70 MPH on the freeway. Dropping down to 4th gear at the same speed brought you to about approx 3200 RPM - too much of a jump. .72 wide for the wide ratio or .81 for the close ratio set up would be better as a true 5 speed.
What I don't like about these kits is the fact that Tremec recommends you cut the rear cross member and make it removable for easier servicing. If I recall correctly, for automatic to 5-speed conversions, that's a non-issue because the cross member is already removable for servicing of the TH400 from the factory.
Mine is a 4-speed car, so it does not have the removable cross member, and I don't relish hacking at a perfectly good frame (which I just replaced BTW) to accommodate a 2.5" longer transmission. I'm guessing if you don't do that, then you have to remove the engine and transmission as a unit for clutch servicing.
Meh - Ferrari makes you lower the entire rear subframe (motor, trans/driveline/suspension) to change the timing belt on the older models. Makes engine/trans removal for clutch servicing on a Corvette seem easy, and which doesn't need to be done nearly as often. How frequently does one change a clutch anyway - not too often.
Then you will know your lowest reasonable cruise rpm and can gear things accordingly. I seriously doubt you can get these old school carb'd engines to cruise at 1500 rpm like a new fuel injected LS engine.
This attachment will help you play with gear ratios the cheap way: in a spreeadsheet!
My buddy george did not like his TKX / 3.70 gearset because he felt caught in between gears at his common 45-55 mph back road speeds. So he went 411 and is perfectly happy. He is in 5th at 55. I am doing the opposite and going 323s. I will never use 5th except on the 70+mph turnpike.
Gear ratios: 3.28/2.13/1.57/1.24/1.00/.76.
He ran it for about 5K miles behind his street smallblock. He's going twin turbo now and will install a race style trans...hence the removal of this one.
He opened it up and sent parts to Liberty for inspection (all good) but replaced synchro's anyway.
He's asking $3500 for it all.
JIM
