Detroit speed chassis
The only downside is the price tag. But IMHO you get what you pay for. It's near C7 style suspension.
You can't get all of those things with any other suspension package.
This just makes me drool!
There are other suspension conversions out there, but they focus on handling the HP first, and improving the chassis second, but they retain the stock geometry limitations, which are painfully apparent in the rear IRS. Zero anti-squat geometry means huge rear squat on launch, and resulting toe-in changes, or super stiff rear springs. And the rear toe-in changes during cornering, causing that squirrelly feeling at speed, will remain no matter what you do, as long as you maintain the OEM trailing arm, short of the above 4 or 5 link setup, which has no trailing arms.
Next time I'm over I'll have to get some pictures of the chassis just for $hits and giggles.
The body is out and had the widened fenders grafted on and they're supposed to be working towards paint this winter, then assembly, then interior, etc etc etc. so he's still a ways off
M
And THAT is a comparison I would like to see:
A full Detroit Speed makeover of a C3 frame - VS - a SRIII frame w/ C7 suspension
Either way, the resulting restomod would be basically a C7 with the much better looking C3 Body on it
Hey a guy can dream can't he?
Really hard to go wrong with either, everything I have put my hands on from Detroit Speed has been top notch!
It's 25k or so. And I am not sure if that number includes the updated diff pictured.
But the SRIII frame adds a round tubing frame with greatly enhanced stiffness vs an OEM C3 frame.
Look at the double round tubing run in the rear kick-up area by the rear diff. WOW!
And you know the C7 suspension bits are top-notch.
Hard to go wrong with either one. Just depends on your budget and ultimate expectations....
A full Detroit Speed system would run some less, maybe 16k or so. And retain the basic C3 frame.
The SRIII version "should" handle better, due to the improved frame. But at this level it will take a very discerning driver with some serious skills to be able to tell the difference. It "should" be faster on a timed track.
A back to back comparison test would be an amazing story.
I'll volunteer to drive! Yes - please.
And I will guarantee you that driver skill could make any of the three beat any of the others, the 3 chasses would all be very close. As long as they are all well-tuned.
Now one would hope that a top-notch driver could make the more expensive chassis go at least a little faster than the others. All that light weight aluminum and 50 year better geometry must help at least somewhere on the track!
Carguy: Cargotzman and Metalhead both have 18*10" wheels inside stock fenders, and drive them in competition. Several others have as well.
Search for their threads.
built 700-800hp cars that ran 200 mph at daytona,lemons,sebring,and many other tracks world-wide
using moded c3 frames and factory suspension,and outran ferraris,porsches
look in the older ''chevy power'' books as to how he did it
https://www.duntovmotors.com/Corvett...wer%20Book.pdf
Look for @reno stallion's thread, he has a chassis that is as well prepared as any.
FWIW, Zip Corvette near Richmond, VA has the Detroit Speed front and rear suspensions in their showroom, if you want to take a look in person.
