Bleeder valves on mastercylinder
Old Jan 10, 2003 | 10:50 AM
dogboy's Avatar
dogboy
Default Bleeder valves on mastercylinder
What are they there for. I have one for each chamber. I bench bled the cylinder in the suggested way without using these bleeders at all. What is there purpose.?? Just curious if anyone has them on thiers and if they used them. It is an aftermarket recond. MC btw
Old Jan 10, 2003 | 12:42 PM
72GACRZR's Avatar
72GACRZR
Default Re: Bleeder valves on mastercylinder (dogboy)
I belive they are there so you could do the same when it was installed, like during a yearly fluid change.
Old Jan 10, 2003 | 01:27 PM
R. Bruno's Avatar
R. Bruno
Default Re: Bleeder valves on mastercylinder (72GACRZR)
My car has them and they are handy for bleeding the m/c. No need to do so unless you remove it from the car or run it low on fluid. Just loosen and have an assistant pump the pedal and hold down, as you would with caliper bleeding.
Old Jan 10, 2003 | 02:23 PM
HDIronman's Avatar
HDIronman
Default Re: Bleeder valves on mastercylinder (R. Bruno)
:iagree:
Old Jan 10, 2003 | 09:53 PM
dogboy's Avatar
dogboy
Default Re: Bleeder valves on mastercylinder (HDIronman)
COOL! Thanks
To Bleeder valves on mastercylinder
