‘68 keyed and cranking hot??
Old Dec 5, 2022 | 09:33 AM
Jd21476's Avatar
Jd21476
Default ‘68 keyed and cranking hot??
I am trying to tap into a keyed and cranking hot for my Holley Sniper system. If I go to the ignition switch, which color is keyed hot and cranking hot? Is it PINK?
Old Dec 5, 2022 | 12:29 PM
carriljc's Avatar
carriljc
I suspect it is like my 68. Find the terminal labeled IGN on the fuse box. You can tap there and it should be hot in START and RUN.
I initially ran my EFI controls off that terminal but eventually I installed a relay that picks up from there and the actual power comes from the Horn Relay terminal.
But you can the IGN terminal to power up the control side of the system and get the system going anyway.
Old Dec 5, 2022 | 12:35 PM
Jd21476's Avatar
Jd21476
I checked the IGN but while it is hot while cranking it remains hot with the key off. The only way to kill it is to completely cut my battery which does have a kill switch on it. I know something somewhere is wired wrong to keep this hot after the key turns off but I want to try at the switch.
Old Dec 5, 2022 | 02:24 PM
MelWff's Avatar
MelWff
Just to be clear, you are testing the bottom unused spade for IGN, Top is Battery, Center is Accessory.
Old Dec 5, 2022 | 03:55 PM
Jd21476's Avatar
Jd21476
So mine are not labeled but I checked and what I get is
Bottom:
- Key off - 12v power
- key on - 12v power
-cranking - 12v power
Middle:
Key off - no power
key on - 12v power
cranking - no power
Top:
Key off - no power
key on - 12v power
cranking - no power
What I need is something with no power when the key is off and then key on with power and cranking with power. I understand that my IGN one for the bottom should be that one but I believe someone wired this car rather weird many years ago.
Old Dec 5, 2022 | 06:20 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Bottom:
Middle:
Key off - no power
key on - 12v power
cranking - no power
Top:
Key off - no power
key on - 12v power
cranking - no power
You should never tap into the IGN circuit. Tap into the W/S washer motor circuit. It is key switched and won't interfere with the power supplied to the coil.
Old Dec 5, 2022 | 06:30 PM
Jd21476's Avatar
Jd21476
but its not a cranking hot. The Holley Sniper needs a keyed and cranking +12v
Old Dec 5, 2022 | 06:34 PM
Jd21476's Avatar
Jd21476
I did. Its an accessory. All accessories shut off when you crank the car. That why the windshield wipers stop as the car cranks. Unless your talking about a different connection.
Old Dec 5, 2022 | 06:56 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you have a wiring issue. I tapped off the IGN for my sniper. I used it to power a relay that triggered a hot wire from the battery to a secondary fuse block
Old Dec 5, 2022 | 06:57 PM
MelWff's Avatar
MelWff
Sorry I was thinking of electric choke connection
Old Dec 5, 2022 | 07:21 PM
Rescue Rogers
I think that yellow wire is hot all the time as well
Old Dec 6, 2022 | 12:55 PM
carriljc's Avatar
carriljc
Jd21476
I concur. You need to solve your wiring issues before hooking anything else up to the system. I've been using IGN for decades.
Old Dec 6, 2022 | 12:57 PM
carriljc's Avatar
carriljc
Drivel.
I've been using IGN for a couple of decades.
Old Dec 6, 2022 | 02:34 PM
Jd21476's Avatar
Jd21476
Yeah, its just odd to me that the IGN would not be hot while cranking. The car starts and runs fine but the issue that I have is that my Holley Sniper will remains on all the time and drain the battery unless I use the battery kill switch. I believe by doing this it clears the LEARN every time unless somoene knows if that makes no difference. I really dont mind turning the battery off cause I have a quick disconnect on the terminal but I just dont know if it clears the computer on the Holley Sniper.
Old Dec 7, 2022 | 12:21 PM
flyeri's Avatar
flyeri
Disconnecting power does not clear the learn table. The tune is not changed in any way. There is an issue though that needs to be fixed. The IGN terminal on the fuse box should be 0 volts with key in the off position and the ACCY position. It should be 12 volts with the key in the on (run) position and while cranking. If you have 12 volts with the switch off, there is a problem. I have a 68 also and my Sniper gets its "pink wire" power through the IGN terminal.
Just to be certain, the IGN terminal is the bottom one, in the middle, right above the little INST LPS fuse.
To ‘68 keyed and cranking hot??
