Best heads for ZZ3?
So, I see where Edelbrock is offering a new D-port head for small blocks, and I know a lot of you like AFR's stuff. Would I see enough difference if I changed?
Even if not, what would you say the best head for this engine is? Is the AFR 180 too "small"?
If I was looking to add some performance to a stock ZZ4 or ZZ3 I'd look at adding a little bigger roller cam and/or 1.6 rockers.
If I was going to go with a set of heads right now, I'd go with Edelbrock Etec 200's and they are probably are a little big for my street driven ZZ4 and would be better on a 383 stroker, 400 or one of the stroked 400's. I heard and read that the larger runners decrease velocity of the air charge and will cost some power on a 350 at low and mid range, where most of my driving is done.
HP = 0.25714 x cfm x # of cylinders
Flow (cfm) / Power (HP)
100 / 205.7
150 / 308.6
200 / 411.4
250 / 514.3
300 / 617.1
350 / 720.0
For a street engine, the secret is to have the cylinder head flow as much cfm through the smallest intake port. I have started a chart for this, here are the top five:
Average CFM/CC from 0.300”-0.500” Lift
1. AFR 180 (1.28)
2. Edelbrock Performer 74 cc (1.26)
3. Edelbrock Centerbolt (1.26)
4. Edelbrock E-Tec 170 (1.25)
5. Edelbrock Performer 64 cc (1.25)
All very close, but AFR 180 flows more cfm per cc of volume. I believe the flow per volume is a good indication of torque because it related to port velocity.
Using the top five from above, lets look at the actual flow of the heads.
Average CFM between 0.300”-0.500” Lift
1. AFR 180 (230 cfm)
2. Performer 74 cc (215 cfm)
3. E-Tec 170 (213 cfm)
4. Performer 64 cc (213 cfm)
5. Centerbolt (208 cfm)
Using AFR’s formula from above, these are est. HP numbers (just for comparison):
1. AFR 180 = 473 HP
2. Performer 74 cc = 442 HP
3. E-Tec 170 = 438 HP
4. Performer 64 cc = 438 HP
5. Centerbolt = 428 HP
Finally, you need to look at the intake cfm versus the exhaust cfm or the Intake/Exhaust ratio. You can have a great intake port and make some serious torque, but you have to get the gas out of the cylinder head also.
Average Intake/Exhaust Ratio from 0.300”-0.500” Lift
1. E-Tec 170 (77%)
2. Performer 64cc (77%)
3. AFR 180 (76%)
4. Performer 74cc (73%)
5. Centerbolt (70%)
According to Lingenfelter, between 75-85% is optimal. Note: E-Tec 200 is one of the best at 82% and the ‘Vette head from the ZZ4 is also excellent at 80%.
If you can afford the AFR 180, I would go with those, if not, I think the E-Tec 170 would be my second choice. I think they require a Vortec style intake.
