Reassembling my engine
Old Dec 13, 2022 | 12:43 PM
Punkchachi's Avatar
Punkchachi
Default Reassembling my engine
I recently did a complete tear down and had a machine shop do some work on my 400sbc. I was meticulous in my tear down, labeling, taking pictures and organizing parts. The issue is, because of how long it was at the shop and available time on my end, that was over 6 months ago. I was wondering if there are any reliable youtube videos or books that walk through exactly how to reassemble it. Like all the little stuff that I would likely forget doing or not know to do because this is the first time I have torn an engine apart. Any advice is appreciated. Thank you!
Popular Reply
Dec 13, 2022, 07:50 PM
stingr69's Avatar
stingr69
This is the bible. Mine is just about worn out. Its a must have to tear down and reassemble a small block.
Old Dec 13, 2022 | 07:07 PM
Kirk H's Avatar
Kirk H
You might want to say what size motor you have, horsepower, and the year of the Corvette. There are plenty of "How To" books on the market. How to rebuild your small/big block Chevy has been around forever. If you took pics, that should help a lot. Get the A.I.M. (factory assembly manual) from one of the many vendors on this forum to aid in the process of brackets, hoses, etc. If you've never done this, this may be a lot to learn and there will be special tools needed (torque wrench, ring compressor, etc). There are plenty of specialists here to help you out but you will need to ask them particular questions and give them your engine particulars so they can quickly answer your questions. Without a book, there are plenty of places to make mistakes (like putting pistons in facing the wrong way, or putting rod or main caps on backwards or in the wrong location).Take your time and read before doing something you can't undo.
Good luck.
Old Dec 13, 2022 | 07:15 PM
Punkchachi's Avatar
Punkchachi
Good luck.
It’s a 400sbc (1971 Gen 1 SBC) so it wasn’t one of the engines for the 78 C3. I have a hanyes manual and an assembly manual. I have a ton of tools, all the specialized ones needed. I just haven’t resembled an engine before. When I watch various YouTube videos/summit videos I’ll find another that is contradictory or see comments that say “you did this wrong, never do that”. So I’m just looking for a reliable source really. So far the Haynes has been good, I just don’t want to screw up.
Old Dec 13, 2022 | 07:47 PM
interpon's Avatar
interpon
I would use your how to rebuild v8. Books and compare step by step with video series like this…and why not double check with forum too
Old Dec 13, 2022 | 07:50 PM
stingr69's Avatar
stingr69
Old Dec 13, 2022 | 08:53 PM
RickM Z06's Avatar
RickM Z06
Has that 400 been in your car before? A true siamese bore, early 70's 400 SB takes an externally balanced flex plate/flywheel & front harmonic balancer.
Old Dec 13, 2022 | 09:03 PM
OldCarBum's Avatar
OldCarBum
This is the Bible!
I built a couple of big blocks back in the day using the big block addition of this book.
The big question is:
What if any performance modifications did you make during the machining of the block and heads, and what if any aftermarket performance parts did you purchase.
Simple honing, boring or slight decking shouldn’t cause any issues using these books, but if you purchased high compression pistons, a stroker crank kit, performance camshaft, aftermarket heads, different rockers, pushrods etc, then these books will do you little to no good at all.
Old Dec 14, 2022 | 06:58 AM
66RAY's Avatar
66RAY
Default Engine Reassembly
David Vizard "How to Rebuild Your Small Block Chevy." Classic how to manual, photos, advice, tools etc. Its been a helpful resource for my garage budget 383 stroker build.
Old Dec 14, 2022 | 07:11 AM
derekderek's Avatar
derekderek
I would find somebody to install the crank, pistons back into the block. It is too easy to eff up. The rest can be done with books and vids.
Old Dec 14, 2022 | 07:54 AM
augiedoggy's Avatar
augiedoggy
Good thing to mention as ive seen threads where people got this wrong and tried using these components from the stock engine. Also im sure the OP knows this but be sure to make sure both the heads and the head gaskets have the steam holes and the gaskets are lined up with them properly.
When I assembled my engine I used multiple you tube videos for basically every procedure along the way. youll want plastigauge to measure bearing tolerances.. I remember being intimidated in the beginning but then realizing its wasnt all that bad at all.
Old Dec 14, 2022 | 11:43 AM
Danish Shark's Avatar
Danish Shark
This guy made a whole series on how to rebuild. Lots of good information there. It's for a big block, but most of it is the same anyway:
https://www.youtube.com/@johnnykcarsnguitars/videos
Old Dec 14, 2022 | 01:33 PM
wwiiavfan's Avatar
wwiiavfan
It might sound silly, but a few winters ago, I watched the entire PowerNation/Engine Power series with Pat Topolinski.
They do a good job of explaining things and repeating and drilling on the important basic stuff of engine building, like degreeing cams, valve clearances, gapping rings, etc. Oh, and zero drama and hard selling of sponsor's products, so you can focus on the learning.
If nothing else, it might help you catch some of those small gotchas that you are taking about.
Old Dec 16, 2022 | 10:33 PM
Sqr's Avatar
Sqr
my one advice to a first time assembler is make sure you get the large end of the connecting rod orientation correct or the engine will not turn over. My second advice is to turn the engine over after every new part installed so that can pinpoint the piece which is giving you trouble. That way you can immediately redo the error and avoid hunting down issues when the engine is completely assembled.
good luck
Old Dec 16, 2022 | 10:40 PM
Punkchachi's Avatar
Punkchachi
I’ve gotten all the pistons and cranks installed, that was a job trying to do it alone while everything is slippery from the oil.
I’ve watched powernation a good amount and they drop a lot of good tips.
thanks for the help so far! No issues yet but I still have a bunch to do!
Old Dec 16, 2022 | 10:41 PM
Punkchachi's Avatar
Punkchachi
good luck
Turning over the engine is a good idea. I’ve been spinning it after each piston install but I’ll keep doing it.
Old Dec 16, 2022 | 10:44 PM
Punkchachi's Avatar
Punkchachi
Yeah it was in the car when I bought it. I put new heads, rockers, pushrods and lifters last year because the heads on it were trash. I had them do steam holes last years when I swapped the heads.
Old Dec 19, 2022 | 12:16 PM
FormerBiker's Avatar
FormerBiker
Just a tip that I learned many moons ago when I rebuilt Chevy. Get some short length rubber gas line tubing that will fit over the connecting rod bolts. Put them on when you install the pistons . This will prevent the accidental "nicking" of your crankshaft journal.
Don't ask how I know.
To Reassembling my engine
