Center Console Gauge Question
Old Dec 14, 2022 | 03:52 PM
OldCarBum's Avatar
OldCarBum
Default Center Console Gauge Question
I’m getting close to installing the gauges back into my center console and I will be replacing all the old oem gauges with new oem gauges.
I’m just wondering what these plates with the windings were for on the center console gauges and if they are necessary.
I don’t see them for sale anywhere.
Thanks!
Greg
Old Dec 14, 2022 | 04:18 PM
Hazmatr's Avatar
Hazmatr
Hi. Those are ohm resistor that were needed for the original gauges to display correctly; based on sender resistance. You will need them if using original gauges. Someone here may have some, probably used, that is how I found some. You'll also need fiber washers and insulators.
http://repairs.willcoxcorvette.com/?...&s=temperature
Old Dec 14, 2022 | 06:30 PM
OldCarBum's Avatar
OldCarBum
Perfect!
The Wilcox link is nice to have!
Thanks!
Old Dec 16, 2022 | 07:35 AM
69ttop502's Avatar
69ttop502
Yea the new OEM type gauges don't use those resistors. I have one of the new fuel gauges on mine and it works perfectly.
Old Dec 16, 2022 | 11:12 AM
OldCarBum's Avatar
OldCarBum
I purchased all the gauges from Corvette Central.
I looked at their website and some of the gauges state in the spec’s that the gauge has an internal resistor and some of the gauges don’t make the statement.
I’ll call Corvette Central and see what they say or contact their supplier.
All the gauges came in GM boxes.
I’ll just need to do more research.
69TTop502, Thanks for the heads up!
To Center Console Gauge Question
