74 not sitting level in rear
Old Dec 17, 2022 | 01:06 AM
CiCiC3's Avatar
CiCiC3
Default 74 not sitting level in rear
There is almost an inch difference from side to side looking at the back of the car. The back wheels have the correct camber and everything is stock in the suspension. Hmmm
Old Dec 17, 2022 | 05:56 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Check the front. A weak spring on the right front will make the left rear high. A stuck shock? A bad rear spring?
But I would start up front.
Old Dec 17, 2022 | 08:16 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Is it new to you ? did it ever sit level before? Are the rear spring bolts adjusted the same? any recent work done to the car?
Old Dec 17, 2022 | 09:05 AM
Bikespace's Avatar
Bikespace
Post photos!
And before you make any adjustments, lift the car by the front crossmember (don't dimple it, use a block of wood), and see if the lean goes away. As others pointed out, the issue may be in your front suspension.
Old Dec 17, 2022 | 10:02 AM
interpon's Avatar
interpon
Does the front have a height difference as well? What is measured to lip at all 4?
Old Dec 17, 2022 | 12:02 PM
CiCiC3's Avatar
CiCiC3
yes I think it maybe the front. I’ve been using spacers due to weak front coils and I may have lost some. It’s time to get new front springs but we’ll see if putting spacers back helps first..
Old Dec 17, 2022 | 12:09 PM
Bikespace's Avatar
Bikespace
You should have put this information in the first post.
Where are you putting spacers? New front springs cost less than a tank of gas. Don't cheap out on your Corvette.
Old Dec 17, 2022 | 01:52 PM
ctmccloskey's Avatar
ctmccloskey
By adjusting the length of bolts that attach the rear spring I am able to raise and lower the rear end. Check your spring mounting hardware and be sure they are the same length. I had a Chevy dealer re-build my differential and they re-installed my rear spring with shorter bolts which raised the car up so high I could see the spoiler in the rear view mirror. It almost look liked it was jacked up in the rear like old hot rods. With the right length bolts she sits perfectly level and looks great.
A blown shock absorber might even cause a difference in the rear side to side height.
Old Dec 19, 2022 | 01:15 PM
CiCiC3's Avatar
CiCiC3
I called the Chevy dealer near me to get the front springs replaced and they want to look at it first but will do it. My question is what will standard springs do to the ride height in front? And did they make a special heavier duty spring for the BB? Thanks!
Old Dec 19, 2022 | 01:29 PM
CiCiC3's Avatar
CiCiC3
Well all but one fell out. If I was to ever use them again I would try putting a velcro strap around them but new springs is what Im working on having someone do. Back in 74 most Chevy's had a bouncy front end by today's standard so I don't know how much new springs will tighten that up. If it's still too springy I would need to go to coil-overs or something? The spacers did deaden it up a bit but they ruin springs I know.
Old Dec 19, 2022 | 01:38 PM
Bikespace's Avatar
Bikespace
What are you calling bouncy?
Stock springs are longer, and lower rate. There were several different higher spring rate springs available. 475 might be the sweet spot. I have 550s installed in my 80, and they are quite stiff. The aftermarket springs are often shorter, so you get a bit of free lowering, too. Below is a photo comparing the old and the new.
However, the term bouncy means that the car continues to oscillate. This happens if your shocks are worn out, or absent entirely. This is often cured by new shocks, in OEM spec, or better. Many here use a mix of Bilstein HD and Sport shocks, or adjustable shocks.
So do you need new springs, new shocks, or both? Can you post photos?
Old Dec 19, 2022 | 02:58 PM
CiCiC3's Avatar
CiCiC3
What do I mean by bouncy? Well it's the same as you see in old movies such as Clint Eastwood as inspector Callahan where they come to a screeching halt, hop out, handcuff the bad guy and the car is still jumping back n forth and up and down. Granted they were real smooth overall but a lot like a boat ride feeling coming that way from the factory.
I do have good Bilstein's all around but to get the firmness I want I'm going to have to go to an aftermarket stronger shorter version spring like you have listed. Meanwhile taking care of this should make it level. I have a good stock leaf spring in back that was rebuilt in 1998. Looks to be in good shape and is firm, maybe too firm I'm not sure. The shop at the Chevy dealership will probably have a good evaluation of it all when I take it in Wednesday. They have an old car expert on the staff.
Old Dec 19, 2022 | 03:04 PM
Bikespace's Avatar
Bikespace
If you already have Bilsteins, I don't know what else to say. Keep us updated, and if the Chevy dealership lets you on the floor, please take some photos with the car on the lift!
Old Dec 19, 2022 | 04:44 PM
Rescue Rogers
bouncy isnt the springs, its the shocks not doing their job
Old Dec 20, 2022 | 12:00 PM
CiCiC3's Avatar
CiCiC3
It came originally with gymkhana suspension and still has the 7 leaf rear spring but the front has always been bouncy and I don't know if the springs were ever replaced. I've owned it for 30 years but it had 4 previous owners and one took it drag racing. The front end has always lifted high on fast acceleration and then bounced down. Friends of mine who have watched from outside the vehicle have said it looks excessive but maybe they are like that. The back reminds me of a go cart the way it feels without much up and down movement. Probably should ask for the 550 lb springs if it is bad springs. Not really many miles on these shocks but they are old.
Old Dec 20, 2022 | 12:08 PM
Bikespace's Avatar
Bikespace
Can you post a photo? Did you put the Bilsteins in, or did the car come that way? They are simple to replace, and likely need to be. Perhaps a previous owner "adjusted" them for drag racing.
Front coil springs are unlikely to go bad, unless they've been in a fire, or modified on purpose, but the PO may have replaced them, too.
EDIT: @interpon posted the details of his FE7 Gymkhana suspension rebuild on this Forum (link below). I think he went with 475 front springs. It might give you a starting point if you need to replace things.
https://www.corvetteforum.com/forums...questions.html
Old Dec 20, 2022 | 01:06 PM
Rescue Rogers
Drag racers want that so that the weight transfers to the rear.Either he drilled and drained the shocks or bought them that way.
unless the springs are sagging then they are not an issue. If one side is lower than the other which happens over time then yes they are bad and thats why some folks use shims to level them out but are a very bad choice for a solution. If you have shims get new springs. If your suspension bounces more than one, replace the shocks.
Dig up a video of a trophy truck going over a jump. you will see the suspension extend and when the truck comes down that suspension absorbs the impact but doesnt spring back up...thats what yours should be doing on a lot smaller scale. New springs will tend to make the front sit high so you may have to cut a half a turn or more off to get the correct height...when adjusting suspension you have to roll the car about ten feet in one direction and then back to the original spot or just take it for a drive to get tthe suspension to settle. The friction of the tires wont let it sit properly otherwise
To 74 not sitting level in rear
Old Dec 20, 2022 | 03:18 PM
CiCiC3's Avatar
CiCiC3
maybe you are right about it being the shocks instead. I did install them but after researching it sounds much more likely that the shocks are more the culprit. Spring’s don’t go bad that often at all it sounds like. I’ll pull off a front shock and check how worn they actually are. I actually put Monroe’s in front and don’t remember why. Does it really matter much which shock you go with on a C3 because someone I thought knew what they were talking about told me it doesn’t.? Thx
Old Dec 20, 2022 | 03:28 PM
Bikespace's Avatar
Bikespace
This is why we ask for photos up front. Every thread like this turns into an episode of House M.D.
Yes, the shocks you choose do matter, otherwise we wouldn't be changing them. Monroes are probably close to stock for a base C3, but probably not for FE7/gymkhana (if that's what is still in there). I got a great deal on my 550 springs, and paired them with Bilsteins, and that worked fine, but I'll upgrade to double-adjustable semi coil-overs at some point. But my C3 is a sports car. If I want a plush ride, I'll drive my old GM truck.
Old Dec 20, 2022 | 03:47 PM
Hopper12's Avatar
Hopper12
Hi CiCi, you haven't mentioned how old the Bilsteins are. I would be shocked if it's not bad shocks. (sorry)
I'd start there. 30 minutes and you'll know.
