68 427 Engine Oil Pressure Line
Old Dec 21, 2022 | 07:41 PM
Planenut99's Avatar
Planenut99
2nd Gear
Default 68 427 Engine Oil Pressure Line
Hey guys, I recently bought a nice 68 coupe, 427, 4sp. I have a small oil leak at the metal oil pressure line that goes from the fitting above the oil filter to the engine bracket. It is a 1/8” steel line with cone shaped brass compression ferrules and nuts with female threads. I found the ferrule cracked and I’m looking for replacement ferrules or a replacement metal line. The standard ferrules you find in the hardware store will not work.
From the online ads, it appears that they went to a cone shaped fitting with male threads for ‘69 so those parts are different then my ‘68.
Any ideas where to source these parts? I’m new to the Corvette, am I missing something and this isn’t original?
Thanks a bunch!
Old Dec 21, 2022 | 08:34 PM
Avispa's Avatar
Avispa
Here's one source for parts. What you have doesn't look like factory style fittings.
https://www.zip-corvette.com/68-82-c...s-senders.html
You may have to buy the entire gauge line kit to get the compression fittings that connect the line to the bushing that threads into the engine block. They're a special fitting that you may or may not be able to find at the local parts store. I had a leak in the same place and the fittings were pretty well rounded off. I just used a female compression fitting to 1/8 male pipe thread adapter. Not factory but it works.
Old Dec 22, 2022 | 10:30 AM
Hopper12's Avatar
Hopper12
I'll take a look at ours later today, but I believe Avispa is correct - doesn't look like a factory setup (might be better. :-) ). I just purchased the entire gauge line kit for our '68 L71 and will be doing that over the winter. 54 year old plastic lines concern me. Good luck, Paul
PS: great looking C3!!
Old Dec 22, 2022 | 10:40 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It appears you have a '69-'73 big block oil line design. For whatever reason, GM engineers changed out the '68 one-line nylon design to this 2-line where the engine has a hard steel line, and then at the top of your photo, the nylon line runs to the interior. The '67 BB line is a one-piece steel line from the engine to the gauge but there is a spiral bit of hard line like a moonshine still to absorb vibration on the firewall side.
If you are not into absolute originality or judging, I'd keep this design since it was a modification to the '68 design and obviously not a money-saving decision.
Old Dec 22, 2022 | 07:14 PM
ctmccloskey's Avatar
ctmccloskey
The one that came on my Early October/67 C3 had a clear plastic (NYLON) tube going from the back of the oil pressure gauge to that "Block Fitting" shown above.
After seeing it I removed it and put a SS Flexible Braided line kit on the gauge and now I don't have to worry about a shower of HOT Oil shooting all over from behind the gauges. I would guess hot oil on the back side of the dashboard might lead to a fire.
The SS flexible Hose kits are available from Summit as that is where I bought my line kit. I will still replace it every 25 years just to be safe. The inner rubber hose still dries out over time.
Old Dec 25, 2022 | 09:38 PM
forman's Avatar
forman
I put my own twist on the line
Old Dec 26, 2022 | 10:58 AM
Planenut99's Avatar
Planenut99
2nd Gear
I like the copper with the spirals. Used that in aviation for years. Found that Summit sells copper oil line and the ferrules in their nitrous stuff. I think I’ll do something similar. Thanks everyone!
Old Dec 26, 2022 | 12:43 PM
Crimson Thunder's Avatar
Crimson Thunder
Off Topic but I love those wheels on your car.
To 68 427 Engine Oil Pressure Line
