68 Wiper Over ride Switch
Old Dec 22, 2022 | 10:53 AM
76yellow's Avatar
76yellow
Default 68 Wiper Over ride Switch
How can I test it ? I took an ohm meter from the terminal to the case and it does nothing !
Old Dec 22, 2022 | 11:17 AM
carriljc's Avatar
carriljc
I'm guessing you mean the little **** down below the steering column?
IF so, then start the car and pull it down. If the door opens then it works. If it doesn't work, then swap the hoses over to the headlight override **** and pull down on that one. If it works, then there it is.
Old Dec 22, 2022 | 01:09 PM
76yellow's Avatar
76yellow
I'm talking about the switch between the two vacuum over ride pull downs. It has one wire going to it. Supposedly it's to stop the wipers so you can change them !
Old Dec 22, 2022 | 01:39 PM
71 Green 454's Avatar
71 Green 454
Correct, it removes the ground.
https://www.corvetteforum.com/forums...nder-dash.html
Old Dec 22, 2022 | 08:56 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I saw in an old thread you switched to a toggle witch...excellent choice, you will never have a dead battery with that choice. If you didnt know, on a 68 if that switch is left in the open or ungrouunded position irt will eventually drain your battery as the wiper motor will leave the park position solenoid energized
To 68 Wiper Over ride Switch
