Flywheel
Old Dec 22, 2022 | 01:58 PM
harryd66's Avatar
harryd66
1st Gear
Default Flywheel
Can a flywheel be installed backwards on a 1969 Corvette backwards on small
block Automatic?
Harry
Old Dec 22, 2022 | 02:21 PM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
I think so
Old Dec 22, 2022 | 05:22 PM
Duane4238's Avatar
Duane4238
Flywheel on standard tranny with a clutch and pressure plate. Flexplate on an automatic.
Old Dec 23, 2022 | 06:20 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Agreed, sounds like a trick question. Trying to keep us on our toes.
and why would you want to flip your flex plate over?
Old Dec 23, 2022 | 06:44 AM
taint's Avatar
taint
Der, so you can go fast in reverse.
Old Dec 23, 2022 | 06:46 AM
4-vettes's Avatar
4-vettes
Or perhaps damaged ring gear teeth. But wouldn't you just replace the flex plate?
Old Dec 23, 2022 | 11:30 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I don't recall if the dowel pin(s) on the Corvette crank are oriented such that if the flexplate were flipped the bolts would line up. However, from what I read it's certainly possible on other GM cars. The issue that occurs is that reportedly the starter gear won't engage with the ring as it places the teeth more rearward than what is needed. Seems it would also cause torque converter bolt issues too.
To Flywheel
