Did some maintenance on the strut rods and u-joints and now can't get the brake pads spread apart to reinstall on rotors....one side went on but can't collapse the pistons on the other side .......what's a guy to do?????
Hi and welcome
Open the bleeder on the stuck side and squeeze the pad evenly so the pistons go flush with the caliper.
Insert a socket that is about 1 and 1/2" top to bottom between the pads and insert the caliper in place, and tighten the bleeder.
Measure the thickness of your rotor. If you have a table-saw, rip a piece of wood just a smidge thicker than the rotor.
Jamb that stick in the caliper until the pads clear the rotor, then remove.
Like Peterbuilt said, open a bleeder. But I would attach a couple feet of clear hose and run the DOT3 into a plastic bottle.
Top off the master.
So I won’t need to bleed the system to get any air out, right? Fantastic, thanks guys…..
Top off the master.
Sometimes when the pads & pistons are shoved into the bore more than normal operation, it stirs up some corrosion that has been dormant.
Using clear tubing / bottle will show if further flushing of the caliper is needed.
Just leave the brake pedal alone if you see rusty DOT3 and open both inner & outer bleeders and allow to gravity bleed for an hour or until the fluid drips clear.
Removal of master lid will allow the system to drain a bit.
