Clacking returns
Old Dec 31, 2022 | 11:13 PM
MarkDawson64's Avatar
MarkDawson64
Default Clacking returns
Hey all! A few months back I posted about the pretty horrific noises the engine on my ‘82 CFI had been making. At the time, the oil in the engine had 1200 miles on it, but I figured I’d change it just to see what happens, and surprisingly the noises went away. Unfortunately, 1700 miles on this new oil and it’s back what could this possibly mean? For context, the engine makes a terrible clacking or ticking noise for about 2 minutes on a cold startup, but smooths out eventually. Once the car is warm, the noise won’t appear if I turn off the engine and back on. I’m using valvoline vr1 10w30 oil and a wix oil filter. I’ll attach a video if it helps at all. Thanks everyone!
File Type: mov
Old Dec 31, 2022 | 11:51 PM
MarkDawson64
Sorry for the double post y’all! I tried to post the first one and it said there was some sort of network error, but it ended up posting anyways
Old Jan 1, 2023 | 12:02 AM
69L88's Avatar
69L88
The noise you are hearing is from the hydraulic lifters. You may want to try Liqui-Moly additive to see if that will work.
Old Jan 1, 2023 | 01:58 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Clacking on start up means one or more of your lifters are bleeding off when sitting for awhile. Not totally unusual. But taking up to 2 minutes to refill is.
if this was my engine I would be replacing all those lifters with the best quality lifters you can find. And redo the cam breakin procedure.
as you remove all the old lifters check that they all spin freely.
Old Jan 1, 2023 | 02:59 PM
OMF's Avatar
OMF
Put about 1/2 quart of marvel mystery oil in your engine oil and run to the next oil change like that.....it might flush and clean it out.
Old Jan 1, 2023 | 06:57 PM
62corvette's Avatar
62corvette
A second possibility is piston slap. Usually doesn’t last 2 minutes, though.
To Clacking returns
