Progress on the Winter Project
Old Jan 11, 2003 | 05:48 PM
sb69coupe's Avatar
sb69coupe
Default Progress on the Winter Project
I finally got started on my "To Do" list of winter projects. I got out in the garage about 10:30 today and stayed out until 5:00. The following progress was made:
Removed hood and stored in guest bedroom
Removed front sway bar
Removed radiator, core support, and shroud
Cleaned and painted the radiator, cleaned the shroud, and got them installed on the new core support. The whole assembly is set aside, ready to drop in.
Removed front shocks. Needed the torch to breal the top nut free on the passenger side.
Tomorrow I plan to put the ol' "Maryland Spring Compressor" into use and remove the rest of the front suspension. Then comes lots of sandblasting and restoration before I reinstall all the new front suspension components. I plan to replace the front and rear seals on the motor while everything is out of the way. Oh yeah, I'm pulling the tranny to replace the clutch too.
Ah, the sweet smell of progress! Pics to follow tomorrow.
Shannon
Old Jan 11, 2003 | 06:27 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: Progress on the Winter Project (sb69coupe)
what a tease! progress with no pics... :jester
