Front Springs advice
Old Jan 8, 2023 | 03:17 PM
70Lt's Avatar
70Lt
8th Gear
Default Front Springs advice
I am in the process of reassembling the chassis on my 70 LT1 and wondering what recommendation you all would have for front springs? Wondering what the best solution is for sourcing a stock setup. Grateful for any advice, pointers in the right direction.
Old Jan 8, 2023 | 03:25 PM
interpon's Avatar
interpon
Maybe close to 72?
any labels or options may influence
Old Jan 8, 2023 | 03:27 PM
70Lt's Avatar
70Lt
8th Gear
Small block AC car.
Old Jan 8, 2023 | 04:05 PM
Avispa's Avatar
Avispa
Check these people
https://www.eatondetroitspring.com/
Old Jan 8, 2023 | 04:14 PM
70Lt's Avatar
70Lt
8th Gear
Thanks for the link!
Old Jan 8, 2023 | 06:13 PM
Fly skids up!'s Avatar
Fly skids up!
For what it's worth, I when I rebuilt my 82's front end I Used Delco with A/C springs and the car sat too high, like a inch and a half. I again replaced them with Delco without A/C springs which brought the car to the correct height. I would bet that the big block spring was somehow misconstrued as a A/C spring and vice versa. No way the weight of a A/C compressor and condenser would make that big of difference. The Delco's doesn't seem to be listed anymore. I believe that they were rebranded Moog springs. At the time both the Moog and Delco with and without A/C springs had the same specs. And they are all 460 pound per inch rate spec.
Old Jan 9, 2023 | 02:13 PM
Kerschmolar's Avatar
Kerschmolar
Corvette Central has correct springs for 68-74. Good way to go if you need complete originality. If you want to have more fun driving consider lowering an inch by cutting a coil off the 460lb springs, using 550 springs or dual rate 480/700 lowering springs (along with shocks and spreader bar). All fit without mods and not that hard to switch around later if desired. My garage has an ever growing pile of original parts.
Charlie
Old Jan 9, 2023 | 02:23 PM
Hopper12's Avatar
Hopper12
Hi 70LT, just out of curiosity, why are you replacing the springs? If you still have your original springs and they are correct, you could just clean them up and reuse them. All new bushings, shocks, etc. will make that '70 ride like new unless there is a problem with the original springs. New or replacement springs could introduce a different set of issues like ride height, etc. that will be hard to know until you get it all back together and see how it sits with weight back on it - and as you know, it's not necessarily a lot of fun to pull it back apart and make additional unintended changes. Just a thought. Best, Paul
BTW, how about some pics of what you're up to? Lots of great help on here when we know more about your build - commentary and pics.
Old Jan 9, 2023 | 02:48 PM
70Lt's Avatar
70Lt
8th Gear
Thanks for the advice Paul. Long story short behind the springs question. I had original springs for it when I took it apart (in 2000). Car was completely disassembled and a friend took it on to build for his daughter. He ended up not building it and it has come back to me. Some parts seem to be missing, numbers matching original drive train is all there, but seem to be missing trailing arms, dust shields, coil springs and a few other bits and pieces. I am sorting through all the parts to get the chassis back together first so I can roll it around. I had a lot of the parts powder coated when I blew it apart, may end up having to redo quite a bit of that. He had the frame stored outside under his porch so that will definitely need to be redone.
Will definitely share some pics
Old Jan 9, 2023 | 02:57 PM
70Lt's Avatar
70Lt
8th Gear
Dropping off in the barn in Oregon. Trailered it back home from San Diego on Dec 30th. When I bought it in 98 it had a 74 front clip on it. Still need to source a front clip for it.
Old Jan 9, 2023 | 04:26 PM
Hopper12's Avatar
Hopper12
Ah, now I/we get it! You might call Mike at America's Finest Corvettes. I've purchased a lot of parts from him. He has access to a lot of great used parts and makes many chassis components. Here's a couple of links. https://www.corvetteusa.com/suspension https://www.corvetteusa.com/ Mike is a very helpful guy and knows his stuff. Not necessarily inexpensive, but you only wince once.
Keep the pics and progress coming. You might want to start a build thread where we can watch your progress, learn from you, and provide some guidance too. Keep it going! Paul
Old Jan 10, 2023 | 09:39 AM
cottoneg's Avatar
cottoneg
My memory is fading. But I think the original front coils were 280 inch/pounds. If you want stock springs, ask the vendor about the spring rate.
I have run F41 springs (550 inch/pounds) and Daytona springs (860 inch/pounds).
I found the Daytona springs a bit much. I like the F-41 springs. They lower the car 1/2 inch and have a bit more firmness to the ride.
To Front Springs advice
