So in the process of rebuilding the factory A/C system the fresh air vent door and air inlet plenum needed to be replaced. Upon disassemble I found the plenum assembly unattached and stuffed into the air inlet cavity. I’m attempting to re install the kick panel with the plenum assembly mounted and it doesn’t seem to want to go back in without serious contortion, to the point I’m concerned I’ll break it trying to stuff it into position.
Can anyone comment on the procedure for this?
The kick panel may have been modified in factory to make clearance and if the previous owner replaced it with a stock one it may need to be trimmed. Am looking for a picture so you can compare.
Air Door assembly does stick out a bit
Here is my left and right kick panels before restoration.
Based on your photo Craig it looks as thought the panel on the left is the passenger side panel. If that’s the case my passenger side panel looks more like the panel on the right side of your photo. Now I’m wondering if the panel was replaced at some point in its life, not sure why someone would do that. It makes me think possibly the panel was replaced with a panel from a non A/C car. Does anyone know if the non A/C car eliminates the fresh air door assembly and therefore uses a different kick panel?
THANKS!!
The non a/c car has a cable controlled air flap so no vacuum actuator like your car.
In this photo, the driver panel is the one on the right; the cut-out panel is for the passenger side. (Look at the curves at the top and envision them being installed next to the curved door openings.) The passenger panel was trimmed out at the factory for A/C cars.
