Thrust angle adjustment on a '72
Old Jan 23, 2023 | 09:13 PM
kansas123's Avatar
kansas123
Default Thrust angle adjustment on a '72
Curious, how does the thrust angle get adjusted on the rear of a C3 ('72), or is it even possible? Thanks
Old Jan 23, 2023 | 09:27 PM
Mooser's Avatar
Mooser
By moving the shims. Imagine one rear wheel is perfectly straight and the other is angled in, the toe would look correct but the thrust would be off. As you move the straight one in and you move the other one out the same amount, toe stays the same but the thrust angle moves towards the center.
M
Old Jan 23, 2023 | 09:31 PM
Mooser's Avatar
Mooser
Here's where I went through it with much help from cagotzmann and several others
https://www.corvetteforum.com/forums...-location.html
I ended up with a rear toe of 0.15625 and the thrust angle being .031" off center (I shifted another .006" and didn't re-measure everything but that should have brought it really close to zero)
M
Old Jan 23, 2023 | 11:11 PM
82LS7's Avatar
82LS7
Just did a 4-wheel alignment in the garage. Just one way of checking and adjusting everything, not shown in this vid is adding extra + castor by milling the trailing arms top mountings holes into slots .500" made a huge difference in high-speed tracking and stability, but only tested to 140 MPH for now.
Old Jan 24, 2023 | 12:13 AM
cagotzmann's Avatar
cagotzmann
Here is how I measure rear thrust angles. To complete the rear thurst / total toe, I do this in 2 steps.
Here is my process for alignment measurement / adjustments.
My DIY Alignment method - CorvetteForum - Chevrolet Corvette Forum Discussion
1. setup the rear wheels equal on both sides relative to the front axle. in picture measures as 9 mm.
2. Then measure what the total toe is, and adjust equal on both sides. (moving shims)
Old Jan 25, 2023 | 07:48 PM
kansas123's Avatar
kansas123
My thanks to everyone.
To Thrust angle adjustment on a '72
