Advice on possible internal engine damage..
Old Feb 2, 2023 | 03:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Originally Posted by im4darush
I know your vote is spun rod bearing on #6. I tend to agree but still trying to rule out all possibilities.
yes but when posters poopoo and don't offer useful info, many like that
Old Feb 2, 2023 | 04:06 PM
HeadsU.P.'s Avatar
HeadsU.P.
W.P. bolts are tight. Wont know exactly what the deal is there until the pump comes off.
I had my hand on every rocker with motor running. No evidence of lash issues. Shroud is not it either.
You can't check sloppy valvelash with engine running very well. The lifters will be pumped up. If you have a collapsed lifter, it may only show up with engine off.
With both VC off, engine off, reach in the drivers window, just bump the IGN key. Go right down the line of rockers noting which valve is open, then check its partners valve rocker arm. Then do the other bank.
Old Feb 2, 2023 | 07:56 PM
Gale Banks 80''s Avatar
Gale Banks 80'
If you suspect any Bearing issues as mentioned above pull the Oil Filter and cut it open. Look to see whats inside and it is such a clear indicator as to the heath of the Bearings. It is such an easy and quick thing to do its always the first place I start.
Old Feb 3, 2023 | 05:57 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Have to agree with Gale. If you spun a bearing it'll look like a ****** makeup in that oil filter.
Old Feb 3, 2023 | 06:45 AM
im4darush's Avatar
im4darush
Confirmed……glitter in oil.
Old Feb 3, 2023 | 08:14 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Ya i said that in post 12 yesterday and he didnt listen
Old Feb 5, 2023 | 07:17 PM
stingr69's Avatar
stingr69
Epic post sir.
