Octane Booster
Old Jan 12, 2003 | 08:38 PM
Motor City Vette's Avatar
Motor City Vette
Default Octane Booster
Does this stuff really work? Any recommendations on certain brands (like Outlaw 108), there's quite a few products on the shelves, from 104 to 108 boost (supposedly). Can this stuff actually harm your engine? Thanks.
Old Jan 12, 2003 | 08:47 PM
Langadorf's Avatar
Langadorf
Default Re: Octane Booster (Motor City Vette)
Most of this off-the-shelf stuff will only raise your octane rating a few points. That means from 92 to 92.2 or so. It's not really worthwhile. The only way to really increase your octane (short of buying race gas) is to mix in with street gas appropriate quantities of xylene (117 octane) or toluene(114 octane) to achieve the octane you desire. These are the chemicals used in high octane race gas. You can get them at your local painting supply co. for about $5/gallon.
Old Jan 12, 2003 | 11:32 PM
CDaniel525's Avatar
CDaniel525
Default Re: Octane Booster (Langadorf)
langdorf,
Could you give us some more information on this?? Like the correct ratios to achieve say 100 octane? or other octanes...Thanks
Chris
Old Jan 13, 2003 | 01:37 AM
Langadorf's Avatar
Langadorf
Default Re: Octane Booster (74VETTE)
Say you want 20 gallons of 100 octane fuel. You have available to you 93 octane pump gas and 117 octane Xylene. You mix 6 gallons of Xylene with 14 gallons of 93 octane pump gas. To calculate the final octane this solution will deliver you first have to calculate the percentage of each fuel types in the mixture. You have 6 gallons of Xylene in a 20 gallon solution. This means Xylene constitues 30% of the mixture. The 93 octane gas constitues the other 70%. You then multiply the appropriate percentage times the octane of each fuel and then add them together to get the final octane. In our example, we get (.3 * 117) + (.7 * 93) = 100.2 final octane. You can use the same method to obtain any desired octane using any different fuel types- just change the mixture percentages and octane ratings accordingly.
[Modified by Langadorf, 12:38 AM 1/13/2003]
Old Jan 13, 2003 | 07:32 AM
SharkByte's Avatar
SharkByte
This brings up another question for me... Could someone please explain what the Octane rating of the gas actually means what what the effect is of higher octane gas? I always run the highest I can find, normally 91 but do I really need the good stuff or would I be better off with a midgrade?
Old Jan 13, 2003 | 08:19 AM
Larry B.'s Avatar
Larry B.
Default Re: Octane Booster (SharkByte)
Check out this link http://www.faqs.org/faqs/autos/gasoline-faq/part1/
Old Jan 13, 2003 | 08:48 AM
SharkByte's Avatar
SharkByte
Default Re: Octane Booster (silvervetteman)
I read that :crazy: :crazy:
Owwww. My brain hurts...
Old Jan 13, 2003 | 08:59 AM
Larry B.'s Avatar
Larry B.
There are four parts. That was part one. You are a fast reader !! There was another doc. on adding toluene to your fuel but I can't fid it off hand. If you do a search on the web you will had information overload. WARNING!! WIL ROBINSON WARNING!
Your 81 should run fine on 93..... BTW I used to visit some friends in Lompoc. :leaving:
[Modified by silvervetteman, 9:03 AM 1/13/2003]
[Modified by silvervetteman, 9:04 AM 1/13/2003]
Old Jan 13, 2003 | 11:28 AM
Langadorf's Avatar
Langadorf
Generally, you should run the lowest octane gas your car can run on without pinging or retarding the timing. If you use a higher octane fuel than what your motor requires, you're just wasting money and possibly gas mileage. Lower octane gas actually tends to release more energy when burned than higher octane fuels thus making it more efficient. Higher octane is for motors with high compression, nitrous, or high boost. Octane is basically just a measure of knock-resistance - higher octane doesn't give you more power unless your engine is built in such a way that it can benefit from it.
[Modified by Langadorf, 10:31 AM 1/13/2003]
Old Jan 13, 2003 | 12:29 PM
BB wowbagger's Avatar
BB wowbagger
Remember that Xylene and Toulen is highly Cancerogenic(sp?) :smash:
:cheers:
Old Jan 13, 2003 | 12:46 PM
Langadorf's Avatar
Langadorf
Default Re: Octane Booster (BB wowbagger)
Carcinogenic is the correct spelling. You need to be exposed to high amounts of Toluene or Xylene for it to be really dangerous (the same goes for gas too). Just be careful pouring it and don't get any on your skin. I've spilled some on my skin before and it immediately makes your skin feel all tingly and kind of numb. If you're worried about it, just wear some rubber gloves and don't go sniffing the fumes intentionally.
Old Jan 13, 2003 | 06:12 PM
CDaniel525's Avatar
CDaniel525
Thanks langadorf....
pretty easy formula to figure it out....i bet it can get expensive tho :p:
Old Jan 13, 2003 | 10:37 PM
rainman69's Avatar
rainman69
Per my friend the ChemE when I asked her many moons ago what "octane" was...
(Simplified for my non-technical Computer Engineering self)
Octane is a rating of a fuel's resistance to burning. A higher octane fuel requires more heat and pressure to burn at the same rate as a lower octane fuel.
e.g. -- 87 octane takes .5 seconds to burn with a normal charge density in an 8.5:1 CR cylinder (hypothetical numbers). 91 octane would take .8 seconds to burn in the same charge density and CR (again, hypothetical numbers). 91 octane would take .5 seconds to burn with a normal charge density in a 10.5:1 CR cylinder (same assumptions as other examples).
Hope that explains octane in laymen's terms that still don't make the real engineers cringe! :steering:
Old Jan 17, 2003 | 01:30 PM
jackson's Avatar
jackson
I looked at Prestone's site for info on their octane booster known as "0 to 60" ... while the ad says it boosts octane ten (10) points ... there is a further explanation if you drill a bit further down into the site. Basically, it says the following: ten (10) octane points = one (1) octane number ... so that one (1) bottle of "0 to 60" will boost 87 octane gas up to as much as 88 octane. BTW, same info informs that "0 to 60" contains MMT. IMHO, not much of an increase & I feel the '10 point boost' claim a bit misleading for all but those who read the fine print.
Old Jan 17, 2003 | 01:41 PM
tonyk72's Avatar
tonyk72
I can buy 110 octance racing fuel at my local gas staion at the pump down the street...It cost over $3.00 a gallon though...don't really look at the prices, it could be closer to $4.50 a gallon. Theres a racetrack nearby, I see all the stock cars get towed in and fueled up in the summer...
Old Jan 17, 2003 | 01:52 PM
emsrescu's Avatar
emsrescu
Default Re: Octane Booster (tonyk72)
i had a friend who raced his bike on 100 octane and he went faster et and mph on 94 octane. :D
Old Jan 17, 2003 | 10:57 PM
Carl in LA's Avatar
Carl in LA
Default Re: Octane Booster (emsrescu)
I see that it has already been said... booster in a bottle wont get the job done. LA gas fell apart two years ago when they went from 92 to 91 octane. That one rating point was enough for me th have to change the timing to keep the engine from knocking. Sad state of affairs for older cars.
Old Jan 18, 2003 | 04:36 AM
shawn_cake's Avatar
shawn_cake
Default Re: Octane Booster (Carl in LA)
http://www.kemcooil.com
Lead Supreme 130
Real T.E.L. in a can..
It is the only octane booster that works..
:yesnod: :yesnod: :yesnod:
To Octane Booster
