80 frame conversion for 79
Old Feb 6, 2023 | 12:06 PM
xluke24's Avatar
xluke24
Cruising
Default 80 frame conversion for 79
I have a guy near me that has a few 80-82 frames that are in good shape at the right price. I own a 79 that's currently body off frame in my garage. It needs pretty substantial frame work and I was looking at finding a better frame. After some research I am still inconclusive if I should try and make the 80 frame work with my 79 drivetrain, by cutting the rear end crossmember off of my frame and weld it on to the better 80 frame, or if I should just use the 80s rear drive train, with the batwing, ditch the Eaton and basically make the car an 80. Anyone have any experience with this? Or any suggestions?
Old Feb 6, 2023 | 02:57 PM
Bikespace's Avatar
Bikespace
Contact @AllC34Me if he doesn't see this thread.
I have both an 80 and a 79. My understanding is that the metal in the frame of the 80 is slightly thinner. Ergo, weaker. Not that they were particularly stiff to begin with. I don't know if that is a consideration.
Also, all 80 frames have removable transmission crossmembers, so that's nice. Be sure to use the trans crossmember from your 79, if possible, to avoid the single notch of the 80.
Best practice might be to use your better iron diff with the aluminum batwing (which will require a shorter driveshaft), but almost all aftermarket rear suspensions ONLY work with 68-79 frames, so YMMV.
Old Feb 10, 2023 | 08:03 PM
Eric P's Avatar
Eric P
Front Diff mount is different too so that’ll take some fabrication
To 80 frame conversion for 79
