power antenna problem
Old Feb 11, 2023 | 01:54 PM
Prysmian46's Avatar
Prysmian46
Default power antenna problem
I just replaced my power antenna on my 82 CE. I bought an Autopro from a Corvette parts supplier. When I removed the broken antenna and compared it to the Autopro that I had bought I found out the Autopro was over an inch longer than my old one. Its bottom mounting hole would not line up with the mounting bracket. I had to fabricate a bracket to mount the Autopro. I got it installed and everything is working OK. Just a heads up if you are considering purchasing an Autopro antenna. I ordered a new plastic cable and will repair my old antenna and keep it if the Autopro breaks.
