richmond 6 speed swap
Old Feb 12, 2023 | 01:58 PM
forman's Avatar
forman
Default richmond 6 speed swap
Im sure its been done ,, anyone have a list of parts and what would be needed to do the swap
came across one and my friend seems to think it wont be that bad of a job I have a lift in my garage and
A great set of television repair tool ,,lol would I have to replace the drive shaft ,, flex plate, clutch ,would I need a hydraulic clutch
just looking for a little direction
Old Feb 12, 2023 | 02:45 PM
carriljc's Avatar
carriljc
I have done it. It's easier if you have a removable crossmember. I made mine removable. Nothing terrible difficult. Just work. Let me see if I can find a picture of my tranny support design. I removed it in 2021 and installed a 200-4R in 2022. I know I have pictures just gotta look.
What do you want to know?
Used the same clutch as the M21, Used a thm-400 out put yoke & a conversion u-joint to hook up the stock driveshaft, and used the same flywheel..... mine was a 10-spline ROD that I ordered from Summit....note that they also sold 26-spline. Anywhich way it would just be a clutch disk change.
Old Feb 12, 2023 | 03:27 PM
carriljc's Avatar
carriljc
Found some old pics on a CD. Quite simple really. If you can do cutting and welding it's even simpler. Nowadays I have modified the crossmember (for the 200-4r) such that the pipes run below it. It would have been smarter to do that then. I will probably be fabricating a whole new crossmember sometime.....
Old Feb 12, 2023 | 03:45 PM
forman's Avatar
forman
Do you need to remove it
Old Feb 12, 2023 | 03:47 PM
carriljc's Avatar
carriljc
I don't understand. Remove what?
...ohh... I think you are asking if you have to remove the crossmember to install the tranny. Well.... not really.... if you want to attach the tranny to the engine and lower it all in place at the same time you could do that..... would take some wiggling because as you can see it is a snug fit. Tranny is the same length as the M-21 but you can not PUSH it up with the crossmember in place..... there is just not enough room.
Old Feb 12, 2023 | 04:03 PM
forman's Avatar
forman
Ok got it
To richmond 6 speed swap
