Working through the Bubbafication of my '73 vette and found a black wire with white strip in the wiring cluster going toward the headlights that is cut. Also, there is a light powder blue thick wire that grounds to the radiator Frame. It is cut coming from the ground but I do not see where it would connect.
Any help is greatly appreciated.
The grounds (rad frame) should be all black, the only light blue wire up front is for the headlights and not ground. Maybe something someone added
The black with white strip, as mentioned above, would go from the bulkhead to the horn-relay/alternator
M
