How do you install the smaller belt?
Old Feb 27, 2023 | 09:16 PM
Redvette2's Avatar
Redvette2
Default How do you install the smaller belt?
I carry an extra alternator belt in the car just in case as I do not have a water pump to crank belt on my car. Seems like there should be one right? Car does not have AC, power steering or any other pullies/belts present. How do you install the smaller belt....do you disassemble one of the pullies or just force it on or? Thanks in advance for any input.
Old Feb 27, 2023 | 10:04 PM
Mooser's Avatar
Mooser
Loosen off the water pump pulley (waaaay loose) and tilt it to get the belt on and then draw it back on with the bolts
M
Old Feb 27, 2023 | 10:05 PM
Mooser's Avatar
Mooser
Or if you're brave
M
Old Feb 27, 2023 | 10:25 PM
AGVI Kicks's Avatar
AGVI Kicks
M
Yep.
Old Feb 28, 2023 | 11:43 AM
71 Green 454's Avatar
71 Green 454
M
Here's one of my file photos:
Old Feb 28, 2023 | 12:13 PM
Redvette2's Avatar
Redvette2
Thanks guys....I'll pass on the screwdriver trick but will do the water pump one.
Old Feb 28, 2023 | 11:17 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I found it easier to mount the upper pulley on the shaft with the four pump hub nuts loose but remove the crank pulley. There's no shaft on the crank to have to get it over and it's easier to just slightly rotate the belt to get the crank bolts to line up. A slight prying is easy if you need a touch more belt length.
Old Mar 1, 2023 | 11:55 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Once the correct length is determined......stick a #1 long thin screwdriver through one of the pulley holes and then through the hole on the pump drive flange......pull up on it to stretch the belt over the shaft.....easy peasey....
Jebby
To How do you install the smaller belt?
